Thread: Aircon compressor not working
  1. Aircon compressor not working
    Jul 2009
    London, United Kingdom, United Kingdom
    Hi all,
    Could you guys help me with a bit of advice? it's an aircon problem that I am experiencing and was wondering whether I could do something before contacting the specialist. I have an A4, 3.0 tdi quattro registered 06. Everytime I turn the aircon on I get just cool air. I am pretty sure the compressor doesn't engage at all since I hear no noice once the aircon is on. I have already checked the fuses but no luck.
    What else should I check?
    Thanks for help in advance!
  2. Re: Aircon compressor not working
    dovski Guest
    If you can get access to Vag-com, and access the aircon, you'll see the pressure in the system versus the pressure range with engine running, I'm not sure what the ideal manual pressure ought to be but mine was out of the lower limit, I recharged from a halfords dispenser which prior to vag-com analysis told me my pressure was fine. Works a treat now, no leaks either.
    Still may be a number of other things but if the system cools down sounds low pressure to me.
    dov
  3. Re: Aircon compressor not working
    Jul 2009
    Quote Originally Posted by dovski View Post
    dov
    Well, I think hte compressor doesn't engage at all. I went to kwik fit and they said that it doesn't work and that it's got enough gas.
    Can you recommend a specialist?
  4. Re: Aircon compressor not working
    dovski Guest
    I'd ask for help in the vag-com users area near yourself. My car is also a 3.0tdi and I cant hear the compressor come in and out either but it works now. Not to say yours isnt shot but 5mins with Vag-com and you can see from the pressure sensors in the system wether the compressor or indeed a sensor is at fault, best option or find an independent vag specialist and run a fault diag first before going down a repair route, could be big bucks for a compressor and recharge.......ask for vag com help on the forums, someone must be near u down london
  5. Re: Aircon compressor not working
    Jul 2009
    Thanks mate, I will look at the vag forum right now.
  1. Is my aircon working right?
    By benjie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2009, 09:53 PM
  2. Please Help Aircon stopped working
    By blackps in forum Golf MK5 - 2004 - 2009
    Last Post: 03-07-2009, 02:25 PM
  3. non working aircon
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2008, 09:38 PM
  4. Passat Aircon not working
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-01-2008, 09:52 AM
  5. My aircon still isnt working
    By nickynibbles in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-09-2007, 09:47 AM
