Thread: Multitronic Service??
  1. Question Multitronic Service??
    Apr 2009
    I'm having a few troubles with my DEQ multitronic gearbox and as I don't know when the ATF fluid was last changed. I thought this would be a good place to start. I've checked on ELSAWIN and it says that it should be filled from the bottom up using a special pump, but spoke to a local garage about doing it and they said they would fill from the side??? Are both ways of doing it correct?
  2. Re: Multitronic Service??
    May 2007
    knee deep in clunge
    14 Post(s)
    To fill correctly there is a special filler (gravity filler)and the oil level is filled from the underside further more oil temp requires monitoring via vag com so the level is correct.
    vag diagnostics, retrofits and general repairs
  3. Re: Multitronic Service??
    Aug 2007
    Hook Hampshire
    21 Post(s)
    pass me your email and I will send instructions
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  4. Re: Multitronic Service??
    Mar 2009
    Cotes d"Armor, France
    I`m not sure you want to use ATF. I believe multitronics use a completely different type of oil.
  5. Re: Multitronic Service??
    Aug 2007
    Hook Hampshire
    21 Post(s)
    ATF is short for "automatic transmission fluid" which is what multitronic requires. however the spec differs from other ATF fluids and the correct part number is G052 180 A2.
  6. Cool Re: Multitronic Service??
    Apr 2009
    Just been quoted £120 from a local specialist to do a flush and refill. Is this about right??
    P.s. A local gearbox specialist quoted almost double that......
  1. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  2. Please Help Car switched from Long Life to Time / Distance service by accident?!?
    By wookiee in forum Golf MK5 - 2004 - 2009
    Last Post: 18-07-2010, 11:25 PM
  3. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
