Thread: Bonnet Release
  1. Bonnet Release
    Jul 2009
    United Kingdom
    Hi Guys,
    Apologies if this has been covered but have been frustrated by my bonnet release catch and didn't know where else to look! Opened the bonnet this morning on my '04 MK5 but now can't close it. Catches are all greased and working so it is a cable issue. The cable handle now appears to have some slack in it, has anyone had a similar problem and is there a quick fix or atleast one that doesn't involve a dealer when I'm pushed for time?
    Thanks in advance,
    T.
  2. Re: Bonnet Release
    Jan 2009
    towcester northants
    the catch is usually at fault
    check to see if it has retuned to stop on cable operating lever
    lubricate with a freeing agent and operate manually to free
  3. Re: Bonnet Release
    Jul 2009
    United Kingdom
    For anyone else who has had an issue this may help.
    I took my bonnet catch to pieces the other day after VW quoted me £170 to check fix and replace the issue...I don't think so!
    Took the locking mechanism out and it was severely corroded/rusted (a good idea to use corrosive metals on a part at the front of the car that gets hammered by water/salt etc!!) spent 20mins working WD40 and grease into the parts and that seemed to get everything working normally again. Replaced all but still it wouldn't lock shut. More playing and frustration but eventually worked out that the locking mechanism had 'dropped' so it wasn't engaging. A quick fiddle and now all sorted...a relief.
    Just a note to all that it may be worth removing and spraying/cleaning so as not to put undue stress on a relatively weak point on the car.
    Cheers all,
    T.
    2 0 0
  4. Re: Bonnet Release
    May 2009
    guildford, england
    Similar problem just experienced on my mark5 - bonnet open to fill up screen wash and subsequently will not close- typical at night, in the dark and needed for a drive around the M25 tomorrow! release lever returns to normal, so suspect might be the same problem as yours - any advise on how to get in and fix this - i suspect that it may also have dropped... any help appreciated - thanks
  5. Re: Bonnet Release
    Jul 2009
    United Kingdom
    Mine's started to play up again much the same as you when filling the water bottle. A bit of fiddling (no tools at hand) got it closed. I'm going to have a look this weekend and see if it has dropped again. Sorry not to be of more help.
  6. Re: Bonnet Release
    Dec 2008
    Worcestershire
    Glad it's not just mine that hads had this problem I've had it happen a few times luckily always when at hoe with access to tools
    I am taking part in the annual Legendary Grand tour of North Devon in Aid of the Childrens Hospice Soutwest organised by the North Devon Mini Register 250 Minis/MINIS, Fancy Dress August Bank Holiday Weekend Please if you can sponser us
  7. Re: Bonnet Release
    Jan 2009
    Hi, guys, i have a mk5, nothing wrong with the release, its just the bonnet is open warning light remains on at all time, and dosent iluminate, even when the bonnet is shut properly, the light is still there, sometimes it goes off and flickers, but generally stays on. if anyone knows any solutions?
    Alternatively can you tel me how to take the switch off, i opened the vw grill, reletivly easy, i can undo the screws on the switch mecanism but cant reach the actual switch, its really far to the left, so iv put everything back on again, can someone tel me how to undo the switch wire as i cant reach it at all or am i going wrong somewhere? cheers guys
  1. Please Help Bonnet release catch not working
    By Trowel in forum Golf MK5 - 2004 - 2009
    Last Post: 15-04-2009, 11:44 PM
  2. Please Help bonnet release broken
    By billt in forum Polo - Derby - Lupo - Fox
    Last Post: 11-04-2009, 12:56 PM
  3. Broken Bonnet Catch Release
    By djaroha in forum Golf MK4 - 1999 - 2004
    Last Post: 22-10-2007, 11:39 AM
  4. Ah - spot of advice on bonnet release catch
    By simost in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2007, 05:15 PM
  5. W Reg Passat - Bonnet Release (at front of bonnet)
    By AndyD in forum Passat - Archive Topics
    Last Post: 01-01-2007, 06:09 PM
