Thread: Turbo lag?
Results 1 to 9 of 9
  1. Turbo lag?
    Apr 2009
    Hi.
    My brand new A5 TFSI with 211 bhp seems to have a bit of turbo hesitation at around 3000 revs. When I put the pedal to the metal it accelerates smoothely from 1500-3000 revs and then for a short while it feels like it runs out of breath for half a second and then it keeps accelerating from there again and on to 4500 revs and more.
    Is this normal with this engine?
    / Chris
  2. Re: Turbo lag?
    May 2007
    knee deep in clunge
    14 Post(s)
    post engine ecu sw version and is this a manual gearbox or multi tronic if the answer is multitronic then post the sw version of this control unit also.
    If you do not have vag com then i advise you take your vehicle into your local Audi dealer and ask them to check this for you and refer to any software updates or tpi documents for this complaint.
  3. Re: Turbo lag?
    Apr 2009
    Hi a8 tech.
    It's a manual gearbox.
    I'm not quite sure where to find the engine sw version? There's a sticker in the car's service book with a lot of codes (letters and numbers). I suppose that sticker displays the equipment level of the car. Could it be there somewhere?
    / Chr.
  4. Re: Turbo lag?
    May 2007
    knee deep in clunge
    14 Post(s)
    You require diagnostic equipment such as vag com but as your vehicle is covered under warranty just ring the dealer and ask them to look into your complaint and possibly arrange a test drive of a similar vehicle to compare
  5. Re: Turbo lag?
    Ramon959 Guest
    I think this is the cam change over point, mine is the same - a small hesitation at 3400 rpm.
  6. Re: Turbo lag?
    Apr 2009
    A software update did the trick. Now there is no hesitation anymore:-)
  7. Re: Turbo lag?
    May 2007
    knee deep in clunge
    14 Post(s)
    good news
  8. Re: Turbo lag?
    Jan 2009
    Lanarkshire
    LaChris - what mpg do you normally get from your A5 ?
  9. Re: Turbo lag?
    Apr 2009
    @ Aldoaccie: I don't messure in mpg but in km. pr. liter. and there I should say it goes around 12 - 13 km/l on average.
  1. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  2. Turbo Lag?!?
    By Shleng in forum Golf MK4 - 1999 - 2004
    Last Post: 05-03-2008, 10:32 PM
  3. Help needed - Severe Turbo Lag
    By cmjw in forum Archive posts
    Last Post: 16-07-2007, 10:02 AM
  4. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
  5. Passat 130Tdi turbo problems
    By Jon Tallis in forum Archive posts
    Last Post: 05-06-2007, 07:52 AM
