Thread: Rear Shock - How Do You Tighten The Retaining Nut???
  1. Rear Shock - How Do You Tighten The Retaining Nut???
    Jul 2008
    Suffolk
    I have the shock absorber and spring off and have swaped the shock with the new one. I now need to tighten up the top retaining nut but the shock absorber piston rod just turns with the nut. How are you supposed to do this? Is there a special tool?
    At the very top of the shock piston there is a flattened bit with which you can turn/hold the piston with, but you can't turn the nut and hold this at the same time.
    The spring is not compressed enough to get the piston into a vice to hold it from rotating.
    Any ideas???
    The retaining nut came off okay because I think it was stiff from not having been undone for a while and it held just enough for me to get it undone.
  2. Re: Rear Shock - How Do You Tighten The Retaining Nut???
    Sep 2008
    6 Post(s)
    Try this link
    http://www.audiworld.com/tech/wheel14.shtml
    You need to compress the spring sufficiently so that the piston rod can be pulled though the wing aperture. To help, use a scissor jack under the strut assembly to help push it up a little. Now hold the strut rod with locking pliers (taking care not to strip the screw thread) and tighten the retaining nut down. Haven't done this job for a while, so can't remember if you need the special tool to tighten it. The slotted head socket costs under £10 from Ebay. The scissor jack helps put tension on the strut, so once the slotted head nut has been hand tightened, you can use an allen-key drive on the top of the strut rod to hold the strut rod while you tighten it. It needs to be tight, but don't overdo it, or you will strip the allen key aperture.
    2016 BMW i3 REx (80k)
  3. Re: Rear Shock - How Do You Tighten The Retaining Nut???
    Sep 2008
    6 Post(s)
    Forgot to mention, only add the nylon lock nut once the wheel is lowered on the ground and then torque to tighten.
  4. Re: Rear Shock - How Do You Tighten The Retaining Nut???
    Jul 2008
    Suffolk
    Thanks for your help!
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  3. How does the Quattro system work?
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
