Thread: Golf tdi 115 bhp (1999)-losing water, help!
  1. #1
    Mar 2007
    Oxfordshire
    My local VW dealer said the head gasket was fine on both cars - when it wasn't. The hole is so small I guess their stanadrd test doesn't show it up - when I took it to them a second time though, they confirmed the fact that the gasket has gone. Most cars can't really be driven when the gasket has gone but these engines seem to run well (except for the loss of water). If you get an independent dealer to do the work make sure they skim the head - they should do it as a matter of course.
    Even though the water in the header was clean on both cars the tank itself was very slightly dirty - it should be absolutely clean (white / transparent).
  2. Smile Thank you Randall977!
    Apr 2007
    Had VW dealer put new head gasket and water pump - no more problems, touch wood! Very many thanks for your advice!
    Mar 2007
    Have got the same car 115bhp Golf, so just a bit worried about developing this fault. How much did the repair cost set you back johne? (just for future reference INCASE I experience this problem)
    Mar 2007
    Oxfordshire
    I have recently bought another Golf GT TDi 115 (2000 with 57K on the clock). The first thing I checked was the header tank for any signs of dirt - all looked fine and I've had no trouble so far. I wonder if over revving could do damage? Just before the gasket went on my Passat my mother red lined it by accident at a junction. My last Golf had the problem before I got it so it could have been badly treated - it was fixed under warranty.
    I wouldn't worry too much, if the car's looked after it should be fine.
    Apr 2007
    If it was not for this website I would not have diagnosed the problem as the fault did not show up when tested by my main VW dealer. The car was a personal new import from France in 1999. the original 115bhp was replaced by VW at 48000 miles (35 months) so the current engine had only 70,000 mikes when it started losing water. It started with only needing topping up every 1000 miles and then got down to around a 100 miles. When VW took the head off the gasket was only slighly perforated (similar to other contributors experience) While the head was off I had the water pump resealed, a new cam belt and thermostat plus a part service. Total cost £1119.00 and they had the car 2 days and supplied me with a new TDI which I did not like as much as my MK 4 which is a much more of a drivers car.
  6. Re: Golf tdi 115 bhp (1999)-losing water, help!
    Doncaster, (Conisbrough)
    Quote Originally Posted by johne View Post
    Thats expensive.
  1. Golf 1.9 GTTDi losing water
    By richiek in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-06-2007, 10:35 PM
  2. Mk 4 Golf TDI Estate losing water
    By Stevie Boy in forum Archive posts
    Last Post: 28-02-2007, 07:42 PM
  3. 1999 VW 110 TDI GOLF VERY SLOW
    By joseph76 in forum Archive posts
    Last Post: 23-11-2006, 05:45 PM
  4. mk 4 golf 115 tdi losing coolant
    By key-matic in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-11-2006, 09:23 PM
  5. RE : 1999 Golf V5
    By cworts in forum Golf MK4 - 1999 - 2004
    Last Post: 06-02-2006, 12:56 AM
