Thread: Air bag fault after replacing battery
  1. Air bag fault after replacing battery
    Tony Guest
    Hi guys,
    Just had my battery replaced at a local garage, which also used another power supply as they changed over the battery, so I didn't have to put in the radio code, etc.
    However, as soon as I drove away, the words 'AIR BAG FAULT' appeared on the on-board computer, and the air bag yellow icon lit up, and stayed on.
    Did a quick u-turn to the garage which ran it through diagnostics and it came up with the following:
    Control module diagnosis VW airbag VW error memory
    04C1 Ignition circuit side airbag
    Driver side front
    Highly resistive
    Error static
    Anyone knows what this means, and more importantly, can this be easily fixed?
    Could I just get the fault reset and hope it doesn't come up again?
  2. Re: Air bag fault after replacing battery
    Quote Originally Posted by Tony View Post
    Hi guys,
    Driver side front
    Highly resistive
    Error static
    Just reset it
    RED SEAT LEON CUPRA WITH REVO REMAP 196bhp AND 241lb TORQUE
  3. Re: Air bag fault after replacing battery
    Tony Guest
    Thanks - will get the garage to reset and I'll see if it comes back. After reading a few threads, some people have said to check the wires, etc under the driver's seat - do you think this would help do anything?
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  3. Question Air Bag fault
    By Cylon2007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-05-2009, 12:54 AM
  4. air bag fault
    By quinny_88_171 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-02-2008, 09:30 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
