Thread: Locked rear brake
  1. Locked rear brake
    Nottingham
    Hi there,
    For some reason I've noticed that one of the rear brakes on my B5.5 2001 TDI Passat has it's brake constantly on slightly. When I have the clutch down and the car is on a slight incline, the car doesn't move back as the rear lifts up (indicating the brake is on) which is when I saw the brake touching the disk so the wheel doesn't move freely when jacked up and no hand-brake on.
    Now then, the question! What's the best way to solve this? Open the brake fluid cap and bleed the brakes a bit? Replace the caliper of the brake? (Which means replacing the pads I guess ) or something else I could try?
    Thanks in advance for the help
  2. Re: Locked rear brake
    Jun 2007
    ireland
    check the handbrake cable on the sticking side it might be seized.
  3. Re: Locked rear brake
    Mar 2009
    i had one that had the same problem handbrake cable was seized
  4. Re: Locked rear brake
    Nottingham
    cheers chaps, i'll give that a look into in the haynes manual... as soon as the bloody weather clears up that is!
  5. Re: Locked rear brake
    135 Post(s)
    2036 Post(s)
    Also possibly a water damaged servo causing the master cylinder to stick slightly.
  6. Re: Locked rear brake
    Nottingham
    that sounds a bit more technical than I know :| where would this be for me to check?
    I have had water blockage in the battery bit (that I need to clean out still).....dunno if that's related?
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Wishbone Front / Rear Axle Bush which brand
    Last Post: 23-05-2009, 12:27 AM
  3. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  4. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  5. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
