Thread: fault codes
  1. Question fault codes
    Jun 2008
    the other day i was in car and the interior lights started flashing off and on and the outside temp on centre console was just two lines couldnt open any of windows except mine and only my door would lock with key then heard a click and everything worked again then went off then came back a few times read codes i got 04c6 which has been there for a while airbag sensor i also got 4674 and 4676 something about steering angle sender and accelerator position sender signal too small any ideas how to start fixing this cheers mark
  2. Re: fault codes
    Jan 2009
    towcester northants
    have you got a water leak?
    same thing happened to my freinds passat and it had water in throttle pedal sender and in wiring
  3. Re: fault codes
    Jun 2008
    yes m8 i have the water leak passenger side
  4. Re: fault codes
    Jan 2009
    towcester northants
    check the drain under the battery
    check the pollen filter housing as they leak
    also check the air con drain tube
    lift the carpet and check the cdl ecu in black box in passenger floor
    remove the accelerator pedal and check for water ingress
  5. Re: fault codes
    Jun 2008
    battery drains are clear pollen filter sealed where will i find air cond. drain tube had carpet lifted dried out as best i could
  6. Re: fault codes
    Jan 2009
    towcester northants
    the air con drain is located in n/s footwell
    if you look at the bottom of the heater at front left corner just to the side of transmission tunnel it is a black plastic tube type object
  1. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  2. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  3. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
