Thread: Clattering sound when idling...fan belt?
  1. Clattering sound when idling...fan belt?
    Smalls Guest
    Hi there,
    I would appreciate any advice for this problem:
    When idling, I get a 'clattering' sound which doesn't sound too healthy. As soon as I press the accelerator (even just slightly) then the sound goes away, i.e. it only happens on low revs.
    A point to note is that this only happened when my fan belt & power steering belts were replaced. I took it back to where it was done and the mechanic said 'I can't hear anything'!
    As result I have a noisy Sharan TDI when stationary in traffic!
  2. Re: Clattering sound when idling...fan belt?
    Jan 2009
    towcester northants
    get the alternator freewheel pulley checked as these break up
    the belt will chatter and the tensioner will vibrate badly
  3. Re: Clattering sound when idling...fan belt?
    Smalls Guest
    Thanks I'll get that checked then.
    A friend heard the noise and just said to tighten the fan belt - something which I haven't done (and wouldn't know how to!)
  4. Re: Clattering sound when idling...fan belt?
    Jan 2009
    towcester northants
    the belt is pre tensioned by a automtic tensioer
    this can be loosened with a16/17mm spanner
    then you should be able to feel the pulley for play and if it is seized
  5. Re: Clattering sound when idling...fan belt?
    Jul 2009
    Bolton uk
    had this problem with mine, it sounded like a black cab idling!
    by the time it got to repairers the pulley had sheared off the alternator, renewed alternator etc to the tune of £350 .
  6. Re: Clattering sound when idling...fan belt?
    Dec 2007
    Montrose Scotland
    Quote Originally Posted by scorpion View Post
    Alternatively the pulley is only £55, (from VW) and a quick Job to replace. Easier with Alternator off car (2 bolts and 2 cables on a 2001 model) Ccheaper part available I'm told from G&S?
    I would agree with the diagnosis having just done my own. Check out my other threads, there is a pic of the part.
  7. Re: Clattering sound when idling...fan belt?
    May 2009
    diss uk
    Quote Originally Posted by Smalls View Post
    Hi there,
    i had the same problem with my sharan tdi it made the noise for about a year then the computer bleaped and said alternator workshop . i had to buy a new alternator and the pulley you have to buy separate from a vw dealer ford dealer the pulley comes complete hope this helps
  1. Cam Belt damaged
    By awmw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-12-2010, 08:54 PM
  2. Air con fan rumbling.
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-08-2010, 10:57 AM
  3. TDI150 Strange sound from ancillary drive belt tensioner?
    By BoraTDI in forum Bora - 1998 - 2005
    Last Post: 21-04-2008, 01:01 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Belt HELP! Fan Belt?
    By whitelockben in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2007, 08:57 PM
