Thread: Creaking Rear Suspension
Results 1 to 8 of 8
  1. Creaking Rear Suspension
    CER Guest
    Firstly thanks to this forum i managed to fix the wet carpet issue, http://www.weirdlittlebiscuit.com/passat/leak/index.htm I found this link in many postings, and therefore didn't have to post again on the issue.
    Now to my next issue, and unfortunately this seems to be a little less clear cut as to what the problem could be, and therefore there does not seem to be a definitive 'how to' guide on how to resolve/identify the issue....hence the post!
    The symptoms are when i bounce the rear suspension of the car, i get quite a lound creaking noise, and i notice it most when getting in and out of the car.
    So essentially what I'm looking for is a 'how to' guide to diagnosing creaking suspension issue. Is anyone able to point me in the right direction?
    Thanks...
    Last edited by Sam; 17-07-2009 at 10:14 AM. Reason: fixed font - made it so I didn't have to break out my screen magnifier :)
  2. Re: Creaking Rear Suspension
    Oct 2006
    I could have asked an identical question as my 2004 Tdi Sport does exactly the same. Was going to just investigate and see what appeared to squeak but will see if any good advice comes from here......
    DC
  3. Re: Creaking Rear Suspension
    Norfolk
    Spray all the bushes, one at a time, with WD40. Test for creak after every bush. That should help you isolate the problem.
  4. Re: Creaking Rear Suspension
    Nottingham
    it's not something as silly as the handbrake not being on hard enough??
  5. Re: Creaking Rear Suspension
    CER Guest
    Would you belive it, it is indeed the handbrake. Thanks.
    Doing a seach now on how best to fix it.
  6. Re: Creaking Rear Suspension
    Nottingham
    what I tend to do is just pull it up further, but that's when I park on inclines. On level ground I tend not to bother.
    You may have to replace the hand brake cables to resolve it's strength I think, but I'm not entirely sure. I'm sure someone here will point you in the right direction
  7. Re: Creaking Rear Suspension
    Mar 2009
    Quote Originally Posted by CER View Post
    exactly the same thing happened to me last night. For a few months I've noticed the creaking noise then last night as I jumped in the motor I remembered reading this post. Took handbrake off and low and behold...problem fixed.
    cheapest fix ever! god knows how much my local VW dealer would have charged for a diagnoses and fix.what is the betting they would have found something that would not have resembled the handbrake being the cause.
  8. Re: Creaking Rear Suspension
    Nottingham
  1. World Debut For The All New Audi A3 Cabriolet
  2. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  3. How does the Quattro system work?
  4. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
