Thread: Fault codes
  1. Fault codes
    Feb 2009
    Spain
    Help i have issues with my 1997 gt tdi ,3 faults are stored 1 coolant temp sensor open short circuit to positive,2 commencement of injection valve open short circuit to earth,3 fuel cut off valve open short circuit to earth. Can anyone give me a clue as what may be prompting these codes as i cannot make the engine run at all also the dash has gone loco are these things related , thanks in advance ,Rob
  2. Re: Fault codes
    Jan 2009
    towcester northants
    check the main wiring loom that goes to the cylinder head
    large screw type connector
    they can corrode and the wires can break
  3. Re: Fault codes
    Feb 2009
    Spain
    Many thanks for the reply to my malady i have now discovered that all 4 of my heater plugs are duff after doing an ohms test and hotwiring them , is it possible for this to be a duff fuseboard ?
  1. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  2. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  3. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
