Thread: seat alhambra 130tdi problems
  1. Angry seat alhambra 130tdi problems
    Mar 2009
    hi new to this site which is great i have to say i have a 2000 x reg new shape alhambra 130 tdi and i have a few minor issues with it 1 when i start it it sometimes reves irraticly for a second or two? 2 clutch pedal has recently started to sag it doesnt return up level with the brake pedal goes into gear ok and if used for a few hours the pedal does return nearer to the proper position ? any help greatly appreciated as there only little problems at the moment but there driving me nuts
  2. Re: seat alhambra 130tdi problems
    Jan 2009
    towcester northants
    1 get diag test done but it could be commencement of injection valve these usually cause car to rev on start
    2 try bleeding the clutch first
  3. Re: seat alhambra 130tdi problems
    Mar 2009
    tried bleeding clutch today but to no avail when i opened bleed nipple to bleed it and pressed pedal it just went straight to the floor and stayed there so i pulled it up and pumped it repeatadly but no fluid came through the bleed hose any ideas ? and what is a injection valve ?
  4. Re: seat alhambra 130tdi problems
    Jan 2009
    towcester northants
    go and buy yourself a gunsons easi bleed
    this will pressure bleed the clutch
    still get a diag test done on the engine this car may not have a commencement of injection valve
    but a diag test will give any faults if there is any
  5. Re: seat alhambra 130tdi problems
    Mar 2009
    tried to pressure bleed the clutch done everything i read from a vag manual but still nothing there are no leaks as the resivour hasnt dropped its level cant understand when its pressurised why no fluid comes out of the nipple when i loosen it what am i doing wrong
  6. Re: seat alhambra 130tdi problems
    May 2010
    manchester uk
    Hi, i have the exact same problem with mine too!!!!. totally identical to yours mate.... but aswell as those my temp sensor isnt functioning properly anymore either (sometimes the needle wakes up when it feels like) otherwise its constantly just dead and whilst driving sometimes the car will begin to rev itself and when i accelerate then press the clutch the revs will rise sharply and suddenly drop. and im not on the accelerator!!!!
    ive had this prob for a while now.. not gettin worse but still there
    ive been told allsorts like its the air flow sensor to a clutch to the temp sensor. ive had enough and will gibe a medal the size of a frying pan to whoever can actually properly help me please!!!!!!!!
  1. Seat Alhambra 1.9TDI Starting Problems
    By atul in forum Alhambra
    Last Post: 27-07-2010, 05:59 PM
  2. retrofit heated seats to 2003 A4 Cabriolet
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2010, 09:55 AM
  3. A3 Seat problems??
    By jasw in forum Audi A3 - Archive Topics
    Last Post: 14-04-2008, 09:08 PM
  4. Happy 50th Birthday To A Spanish Legend – The Seat 600
    Last Post: 15-08-2007, 07:00 PM
  5. Seat Alhambra 130tdi power loss
    By notwenam in forum Touran - Sharan - Caravelle
    Last Post: 29-12-2006, 12:51 PM
