Thread: Accelerating downhill is sluggish
Results 1 to 8 of 8
  1. Accelerating downhill is sluggish
    May 2009
    Oxon, UK
    I have the 2.0 TDi. I've noticed that when accelerating on a steepish downhill gradient, the acceleration is very sluggish, as if there were some governor kicking in. I've not noticed this on the flat or on shallower gradients. Is it just my imagaination, or has anyone else noticed somethiung similar?
  2. Re: Accelerating downhill is sluggish
    Scunthorpe
    Which gear are you in when you do - I was going down a pretty steep hill this morning in 4th without any problems.
  3. Re: Accelerating downhill is sluggish
    May 2009
    Oxon, UK
    I've noticed it in 4th and 5th. I see that you have a GT, which I presume is a different engine? Mine is the SE (110BHP IIRC).
  4. Re: Accelerating downhill is sluggish
    Scunthorpe
    Is yours the 1.6 tdi then? Mine is the 2.0 140 which, I think, is available in SE trim.
    I'll double check again on my way to work today and let you know though, but acceleration shouldn't be sluggish going downhill. If you can - what happens if you coast (engine on, out of gear) down the hill - could it be the brakes cutting in or something?
  5. Re: Accelerating downhill is sluggish
    May 2009
    Oxon, UK
    No, mine is 2.0, but the lower power model. Coasting down hill, the car does what you would expect, i.e. gradual acceleration. It is just when opening the throttle down hill that there seems to be, well, a braking effect for a second or so before the acceleration kicks in. Weird.
  6. Re: Accelerating downhill is sluggish
    Scunthorpe
    That's really odd....
    I've checked this morning and acceleration in 5th and 6th down a steep incline is pretty brisk - If you can easily replicate the problem, drag an angineer out there with you to demonstrate the fault.
  7. Re: Accelerating downhill is sluggish
    May 2009
    Oxon, UK
    OK, thanks for checking that our for me. Much appreciated.
  8. Re: Accelerating downhill is sluggish
    WeegieBob Guest
    I have that - usually after a fast run on a motorway, then slowing down on the off-ramp onto a country road, where within about 100 m almost immediately going over a small drop still slowing, its like the engine takes a "gulp" and there's a brief hesitation.
    I'd always put it down to some form of turbo-lag as it never really caused me an issue and reckoned if it got worse I'd drop it into the dealer to sort it out.
    WeegieBob.
  1. Eratic idling and occasional judder when accelerating...
    By AlTerego13 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-06-2009, 10:16 PM
  2. Knocking/creaking noise in second gear accelerating
    By Fireyjack131 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2008, 08:55 PM
  3. A3 TDI stalling on downhill slope?
    By paulodipoggio in forum Audi A3 - Archive Topics
    Last Post: 04-01-2008, 12:50 AM
  4. Thirst & Sluggish GTI T150 MK4 Driving Me Mad!!!!
    By GazGTITurbo in forum Golf MK4 - 1999 - 2004
    Last Post: 02-10-2007, 05:45 PM
  5. Golf Mk3 Gti 8v Problems Accelerating
    By Mowgs in forum Golf MK3 - 1993 - 1999
    Last Post: 17-02-2007, 07:37 PM
