Thread: A2 1.6 fsi misfire!!!!
Results 1 to 10 of 11
  1. A2 1.6 fsi misfire!!!!
    Hi people got a prob with an A2 1.6 fsi logging a misfire on cyl's 1,2 & 3 then another code of just misfire, codes are;
    vw 16684 or p0300 misfire
    vw 16685 or p0301 misfire cyl #1
    vw 16686 or P0302 misfire cyl #2
    vw 16687 or p0303 misfire cyl #3
    no code for cyl#4!
    all pencil coils & plugs replaced still getting codes present
    all compressions are good no visable probs with wiring etc
    basically the car drives well no lack of power and no misfire but malfunk light comes on and flashes all these codes are then present but car has not missed a beat.
    anyone heard of any software updates or wiring/ecu issues?
    cheers jb
  2. Re: A2 1.6 fsi misfire!!!!
    May 2009
    rhodesia, nottinghamshire
    Hi jb, just had a look on my autodata and it says same for all cylinders..
    Engine mechaanical fault,wiring,ignition/fuel system,injector,ECT/MAF sensor,ECM
    plenty to choose from, could be costly just replacing parts, I would either find a local Delphi Diesel agent or wait till something does go wrong...
  3. Re: A2 1.6 fsi misfire!!!!
    Cheers steve;
    the 1.6 fsi is a petrol not diesel but thanks anyway.
    problem hopefully solved as oxygen sensor has been modified (it has a knock sensor attatched to it) and also needed and full ecu re-set, but if problem happens again the injectors can cause the problem.
    thanks again john
  4. Re: A2 1.6 fsi misfire!!!!
    135 Post(s)
    2036 Post(s)
    A NOX (various oxides of nitrogen) sensor, not knock sensor is incorporated into the oxygen sensor, said quickly NOX and knock can sound very much alike.
  5. Re: A2 1.6 fsi misfire!!!!
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by JONBOY201 View Post
    no code for cyl#4!
    cheers jb
    seen this before and repair is new ecu and injectors honest i will dig the technical repair out for you but i did one last year mil comes on after 2 weeks of resetting there is from memory a time limit for the injectors and the sw version of the ecu which at the time there was no software update available so new ecu fitted and that sorted it
  6. Re: A2 1.6 fsi misfire!!!!
    May 2007
    knee deep in clunge
    14 Post(s)
    ok random misfires logged no running issue
    Because of delayed combustion the engine speed impulse sender recognises an irregularity in the crankshaft rotation. This leads to an entry in the memory. The internal adaptation values in the engine control unit have reached a limit from which they cannot return.
    Disconnect the engine control unit for at least 2 hours from the power supply to reset the internal memory of the engine control unit.
    If the complaint cannot be rectified, replace the injection valves
    As said i had to replace the engine ecu as the suggested reset did not work
  7. Re: A2 1.6 fsi misfire!!!!
    135 Post(s)
    2036 Post(s)
    I have had to replace injectors on the BAD code engine for this.
  8. Re: A2 1.6 fsi misfire!!!!
    thanks guys the problem is sorted for the mo!!!!!
  9. Re: A2 1.6 fsi misfire!!!!
    135 Post(s)
    2036 Post(s)
    And it was...?
  10. Re: A2 1.6 fsi misfire!!!!
    hi crasher soz for very late reply,
    from what i can make out after lots of basic (compressions, wiring etc) testing & lots of live data analasys on road test, after the front or pre cat o2 sensor was replaced with the updated version, the ecu needed a full reset by disconecting the battery for a min of 2 hours as all of the fueling upper limits had been reached, i found alot of info out from a company called erwin audi, you have to pay a small amount for an hour but you have got alot know probs and all w/s manuals to scan through.
    cheers again
    jb
  1. Question Car Tax For 2002 Audi A2 1.6 FSI SE
    By Bristle Hound in forum A2
    Last Post: 28-06-2009, 12:48 AM
  2. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  3. Audi Injects Even More FSI Efficiency Into 2007 Range
    Last Post: 04-12-2006, 08:06 PM
  4. A8 3.2 FSI NOW WITH ADDED QUATTRO SECURITY
    Last Post: 11-08-2005, 08:34 PM
  5. Audi launches efficiency drive with New A6 FSI models
    Last Post: 23-05-2005, 07:34 PM
