Thread: ABS Light - Code 00597
  1. ABS Light - Code 00597
    Aug 2008
    I have been having an intermittent problem with my ABS and often the light would illuminate on the dash, previously this never showed up as a fault.
    Today however I felt a shudder as the light came on and scanned for codes when I got home and to my surprise a fault was logged as follows
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 4D0 907 379 D
    Component and/or Version: ABS BOSCH 5 4174
    Software Coding: 0265108005
    Work Shop Code: BB 34174
    1 Fault Found:
    00597 - Wheel Speed Impulses: Deviation
    35-10 - - - Intermittent
    I have no idea what this even means !!! lol . Can anyone help shed some light on what may be the cause or consequence of this?
    EDIT: I have a 1996 Audi A4 1.9 TDI 110BHP, Engine Code AFN
  2. Re: ABS Light - Code 00597
    Southern County Softy
    20 Post(s)
    From the Ross Tech Wiki
    00597 Wheel Speed Impulses; Deviation
    Possible Symptoms
    Malfunction Indicator Lamp (MIL) active
    Possible Causes
    Wheel or Tire Sizes not the same on all four Wheels
    Wheel Speed Sensor Rotor dirty or damaged/faulty
    Wheel Speed Sensor(s) installed incorrectly
    Excessive Wheel Bearing play
    Possible Solutions
    Check Wheel and Tire Sizes
    Check Wheel Speed Sensor Rotors
    Check Wheel Speed Sensor Installation
    Check Wheel Bearings
    A4 2.5 tdi QS (mapped)
  3. Re: ABS Light - Code 00597
    Aug 2008
    That's great thank you I am sure that the wheels and tires are the same size as they have always been so I am having a guess at the wheel bearing as there is a low droning noise as I drive.
  4. Re: ABS Light - Code 00597
    20 Post(s)
    Also check and clean sensors and rotors.........
  5. Re: ABS Light - Code 00597
    I have just had the same problem on my a4 1.9 tdi it turned out to be the abs ring on the rear disc. Fitted that problem all gone easy fix.
  1. abs light on 97 passat 1.9 tdi
    By artino in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2009, 05:35 PM
  2. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  3. 1999 passat ABS light help
    By jonny VDUB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2008, 01:25 PM
  4. abs light on
    By 1.8t bus in forum Chat - Anything with wheels
    Last Post: 10-02-2008, 06:07 PM
  5. Polo ABS warning light
    By jeffbm in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2007, 12:39 AM
