Thread: Engine Temp
Results 1 to 10 of 10
  1. Engine Temp
    Jun 2009
    Sheffield, South Yorkshire
    About six months ago, I noticed my temp indicator was acting 'funny' in that when I was parked at some lights, I managed to give time to look at the dashboard and noticed the gauge dropped from a constant 90 deg to more-or-less zero. It was a cold day so assumed that with it being only a 1.4e, cooled-down quickly.
    Six months on (I really should pay more attention to the dash shouldn't I) when driving back from MK to Sheffield yesterday, I noticed that it was reading zero again after climbing the M1 hill towards the M42 junction.
    Today then, I watched it all the way to work (occaisionally looking out the windscreen for pedestrians, cars, etc) and it didn't flinch.
    Getting to the point then, the unit looks knackerd so how do I replace as my Haynes manual doesn't cover my crappy 1.4
    Do Motormania carry a good enough replacement part, how easy is it to fit and where does it go?
    Thanks in advance for any advice/help.
    Marillion
  2. Re: Engine Temp
    Jan 2009
    towcester northants
    replace temp sender and reset fault memory
  3. Re: Engine Temp
    Jun 2009
    Quote Originally Posted by towcestervag View Post
    Ok, where is the 'Temp Sender'? and how do I 'reset fault memory'?
    This is looking to be a bigger issue than my initial request for help.
    Can 'Crasher' please reply?
  4. Re: Engine Temp
    Jul 2009
    Manchester
    You want to hope it is your temp sensor rather than the dash pod
    Temp sensor approx £25 and can take you approx half hour to do
    Dash pod £hundreds and dealer only job....
    Haynes should have that in surley?
    Sarah
  5. Re: Engine Temp
    Jun 2009
    Sarah,
    I was driving home tonight and noticed that the temp was showing 90deg (generally average) and pointed this out to the missus. Seconds later, it dropped back to zero even though I was still driving!
    My manual (Haynes) talks about the sensor but states: 1.4 engine, see chapter 3 section 6 where this talks about the throttle housing.
    Still waiting for someone to point me in the right direction though. Where is the coolant sensor?
  6. Re: Engine Temp
    Southampton, UK.
    Quote Originally Posted by Marillion View Post
    Sarah,
    ...Still waiting for someone to point me in the right direction though. Where is the coolant sensor?
    Have you done a search? There have been many threads on this topic.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  7. Re: Engine Temp
    Jan 2009
    towcester northants
    the temp sener is on the gearbox side of engine
    they are either black green or grey dependant on model
    held in with small plastic clip and they have a seal replace with the same and if you do when cold you can save you anti freeze but check seal comes out with sender
  8. Re: Engine Temp
    If you change it yourself make sure you get a retaining clip! I snapped mine when taking the old one off & couldn't use my car for a day as the shop was shut, they are only 99p or so from GSF.
  9. Re: Engine Temp
    Jul 2009
    Oxfordshire
    Quote from a New Beetle sensor change
    "Coolant sensor change - Loosen the coolant tank cap to relieve any pressure that might be in the system, then put it back on, tight. Locate the coolant temp sensor and unplug the electrical connector. The sensor is sealed with an o-ring and held in position with a clip. Pull the clip, then wiggle and pull on the sensor to remove it from it's well. With the cap on the coolant bottle, you should lose very little coolant but it also pays to have the new parts ready to go in immediately. Remove and replace the o-ring (might want to lube it with a little Vaseline or similar), seat the new sensor, push in the retainer clip. Re-attach the electrical connnector."
    Hope this helps.
    Regard, Ian
    Royal Air Force Aeromechanical Engineer
    New Beetle 2.0 2001 72k in Pistachio
  10. Re: Engine Temp
    Jul 2009
    Manchester
    As the man says
    Sarah
  1. 2.5 tdi AKE engine noise
    By brickit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-11-2012, 03:28 AM
  2. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  5. World Debut For The All New Audi A3 Cabriolet
