Thread: GT TDi Cylinder Head
  1. GT TDi Cylinder Head
    May 2008
    Hello,
    I have a Golf Mk5 2004 GT TDi 90,000miles and it has just gone in for a service, to change manifold flap (Emissions Workshop) and to see why coolant going down quickly.
    Apparently I need a new cylinder head fitted and VW will not offer any good will gesture. I can't believe the car is only 5 yrs old and need that. Ive been quoted about 1k for parts & labour. Is that about right.
    Just gutted I've got to churn out that sort of cash.
    Has anyone else had a similar problem or if you can help re price be good to hear from you. Many thanks.
    Matt
  2. Re: GT TDi Cylinder Head
    Dec 2006
    VW will charge you a lot compared to other places...
    I would expect you can get this done for around £600 if you shop around at some local garages,
    Take a look at our supporting companies section.
    I would expect it will cost around £60 for the head skimming and pressure testing, around £100 for the cam belt kit, (which i would change at the same time.) around £25 for the gasket, and around £15.00 in new bolts.
    Where abouts are you??
    Rick
  3. Re: GT TDi Cylinder Head
    Yes Rick,but they told him he needs a new cyl head
  4. Re: GT TDi Cylinder Head
    May 2007
    knee deep in clunge
    14 Post(s)
    The casting cracks but also the egr cooler can be the cause or even both.Remove and install cylinder head is about 9 hours labour and special tools are required to install the injectors although a light dink with the hammer seats them just fine i think the last one i did cost about £2000 all in
  5. Re: GT TDi Cylinder Head
    May 2008
    Yep it is a whole new cylinder head. So 1k is looking good then?! The chap from VW even said that he's seen it happen a number of times on the 2.0 GT TDi engines, well that's nice to know. So why don't VW contribute then if its a known problem.
    I'm from Saffron Walden not far from Cambridge.
    Still sulking about the imminent big spend!!
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  3. GT TDI 6month and new cylinder head !
    By capt cavey in forum Golf MK5 - 2004 - 2009
    Last Post: 15-06-2009, 10:39 PM
  4. Cleaning Tdi Cylinder Head...????
    By djl78 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-05-2009, 10:52 AM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
