Thread: LT35 2.5TDi Starting Problems
Results 1 to 10 of 13
  1. LT35 2.5TDi Starting Problems
    Jul 2009
    LEVEN SCOTLAND
    Hello to the VW club.
    Ok In order to fire up me van I have to do the following 3 TIMES.
    Turn ignition on {glow light extinguishes after approx 3 seconds} turn off ignition , turn on ignition , let glow light go out {again extinguishes after approx 3 seconds} do this again and on the thrid on off I then trun the key fully to start the van ., If this does not work I have to go through the 3 stage process. Plugs have all been checked and are now new, Problem remains the same.
  2. Re: LT35 2.5TDi Starting Problems
    It would seem the plugs are not getting hot enough,have you fitted the correct plugs?
  3. Re: LT35 2.5TDi Starting Problems
    Jul 2009
    LEVEN SCOTLAND
    It was in at my local garage and they checked the plugs apparantly and said they were new plugs .
  4. Re: LT35 2.5TDi Starting Problems
    After you turn the ignition on,listen and wait for the glow plug relay to click,see then if it starts
  5. Re: LT35 2.5TDi Starting Problems
    Jul 2009
    LEVEN SCOTLAND
    Cheers Kenney for your help . the relay clicks within 3 seconds or sooner of turning the ignition on .
  6. Re: LT35 2.5TDi Starting Problems
    Yes,but listen if you can hear it clicking,again,before you try and start the engine,it should click again after the duration of the glow plug heating
  7. Re: LT35 2.5TDi Starting Problems
    Jul 2009
    LEVEN SCOTLAND
    No I have waited upto 15 seconds for another click even with the dash light being out and cant hear any second click Kenney /
  8. Re: LT35 2.5TDi Starting Problems
    It would then seem the relay is not closed long enough to heat the plugs properly,i can only suggest try another relay.
  9. Re: LT35 2.5TDi Starting Problems
    Jul 2009
    LEVEN SCOTLAND
    Many thanks Kenney , looking online for both the relay and the pcm .
  10. Re: LT35 2.5TDi Starting Problems
    Jul 2009
    LEVEN SCOTLAND
    Justr checked again and as long as you are at the engine compartment you can hear it click a second time , roughly 8 seconds after first click . So god knows .
  1. golf mk3 starting problems
    By pooly in forum Golf MK3 - 1993 - 1999
    Last Post: 18-06-2009, 03:16 PM
  2. 2.5TDI Starting Problems
    By DDe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-06-2008, 01:51 PM
  3. Starting problems 2.5TDI
    By tomnch in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-04-2008, 03:22 PM
  4. Starting Problems
    By blergo in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2008, 07:00 PM
  5. A4 2.5tdi starting problems
    By Pat in forum Archive posts
    Last Post: 18-04-2007, 01:15 PM
