Thread: Instrument Lighting
Results 1 to 9 of 9
  1. Instrument Lighting
    Apr 2009
    On my test drive the dash lights were on the whole time. Is that always the case? Or is there a way of turning them off when the lights are not in use. I'm wondering if they're linked to the daytime running lights?
  2. Re: Instrument Lighting
    Scunthorpe
    They're on all the time - as far as I can tell....
  3. Re: Instrument Lighting
    Feb 2009
    Northants
    Quote Originally Posted by james_tiger_woo View Post
    Try turning the headlights to 'Off' from 'Auto' and go into a multi storey or under a long bridge....the dash lights dim and go out. All you can see are the red needles
  4. Re: Instrument Lighting
    Manchester
    I can see this dashboard light getting me and other people pulled by jonny law!!!
    I was following a mk6 home today and noticed that tho the front lights were on the rears weren't, coupled with the fact that there is no indication as to whether the lights are on or not (other than the stereo changing to blue) i can see potential for slapped wrists.
    Maybe not ordering the auto headlights etc wasn't such a good idea in hindsight!
  5. Re: Instrument Lighting
    Dec 2006
    Quote Originally Posted by paul.mgrath View Post
    They are DAY TIME RUNNING LIGHTS... so you dont need to know if they are on all the time..
    If you read the manual you can "learn" how to disable these.
    Rick
  6. Re: Instrument Lighting
    May 2008
    London, UK
    The dashboard illumination is on because of the DRLs
  7. Re: Instrument Lighting
    Feb 2009
    Northants
    Quote Originally Posted by J400uk View Post
    But drive into a multi storey etc and the DRL's don't go out like the instrument lights.
  8. Re: Instrument Lighting
    nebw Guest
    Isn't the instrument backlighting controlled by an ambient light sensor, like the nav screen ? I think it's another bit of trickle down technology from the Phaeton/A8, which have both had this for a few years.
  9. Re: Instrument Lighting
    Jul 2009
    Surrey, UK
    Quote Originally Posted by RickT View Post
    Rick
    Even if you have the switch turned to on, you cannot turn of the headlights. As far as I know the headlights turn on as and stay even of you have the switch turned to off, though they are on dim.
    Some sort of safety feature. If someone knows how to turn your headlights off, let me know as this "safety feature" will ultimately mean more bulbs being used and added costs!!!
  1. Touran 2003 instrument cluster failing
    By jugglerb in forum Touran - Sharan - Caravelle
    Last Post: 21-06-2012, 12:12 AM
  2. dash instrument panel not lighting up at night
    By charles0106 in forum 80 - 90
    Last Post: 10-09-2007, 06:23 PM
  3. Dashboard back lighting going out after 5 seconds?
    By Matt B in forum Archive posts
    Last Post: 03-06-2007, 10:39 PM
  4. Adjusting level of instrument lighting?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-03-2007, 09:24 PM
  5. Instrument Panel Gauges
    By fuelforlife in forum Vento - 1994 - 1998
    Last Post: 21-12-2006, 01:10 AM
