Thread: Ignition Lock Failure warning light
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Ignition Lock Failure warning light
    Jan 2009
    I've had the warning a few times, so I rang Cardiff Audi who told me it was a common thing, they advised me to clean the fluff out of the recesses on the side of the key. Havn't had the warning since
  2. Re: Ignition Lock Failure warning light
    Suffolk
    My ignition lock failure warning light came on a few times over the past month. Was booked in for service at Colchester Audi and phoned them to tell them of the issue. They said it was a common fault and would order the part and replace under warranty. Didn't have to push and couldn't argue with the service I received. They also replaced the two plastic boot hinge covers on the saloon under warranty - I only asked for the broken one too be swapped. Can not fault the service I received - until I was quoted for replacing 4 tyres @ £190 per corner!
  3. Re: Ignition Lock Failure warning light
    Jul 2007
    Quote Originally Posted by Mr Sheen View Post
    Depending on the size and make of tyre, that may not be a bad quote..
    '58 A4 Avant 3.0 TDi Quattro.Meteor Grey,, DVD navigation, Dynamic control (steering & damping), Milano Leather, 5 spoke 18" wheels, Sports Seats (heated), Electric seats, phone prep, Xenon Plus Headligths, Storage & Interior Light Packs, Hill hold assist, Panoramic Sunroof, B&O speakers, 3 spoke steering wheel, powered tailgate, AMI, 6 disk autochanger......
  4. Re: Ignition Lock Failure warning light
    Suffolk
    Quote Originally Posted by simfin View Post
    Having just searched online I think you are quite right. Even a mid range tyre is £160 fitted. They are a 255/35 R19 96Y tyre and sadly I need all 4.
  5. Re: Ignition Lock Failure warning light
    Dec 2010
    london
    So, im now having this issue intermittently
    Ive tried the brand new spare key and it still happens.
    The igntion barrel was replaced just over 2 years ago now for an issue of a sticking key....so out of the 2 years parts warranty.
    Any ideas on how to fix this?
    It doesn't come up all the time.
    I noticed that i cant put on my steering lock now though.
    Any help appreciated.
  6. Re: Ignition Lock Failure warning light
    Ardfern
    8 Post(s)
    What model have you?
    I did not think any B8s had an ignition barrel and I don't know how to operate
    the steering lock which I assume is operated electronically if at all, by using the
    dash-mounted key system.
  7. Re: Ignition Lock Failure warning light
    #17
    Dec 2010
    london
    i have a b8 sline avant 58 plate.
    sorry i didnt mean barrel...more the mechinism that the key is put into. this is what was replaced under warranty.
    the sterring lock does not operate, now i have this issue.
  8. Re: Ignition Lock Failure warning light
    #18
    Ardfern
    8 Post(s)
    I see. It sounds as though you may have to replace the key socket fitting but
    presumably you have tried cleaning the key and what you can reach of the key socket?
  9. Re: Ignition Lock Failure warning light
    #19
    Dec 2010
    london
    Quote Originally Posted by Boy View Post
    Indeed. Tried the cleaning the socket and key....although we have a brand new key and that didn’t work either.
    Has anyone had the socket fitting replaced? If so how much? Can I do it myself?
  1. Boot Lock Failure
    By nomoretears in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-01-2014, 10:37 AM
  2. Replies: 23
    Last Post: 20-11-2011, 06:44 PM
  3. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  4. A4 2002 Brake Pad Warning Light (0)
    By mandilou in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2008, 06:18 PM
