Thread: A4 2.5TDi hard to start
  1. A4 2.5TDi hard to start
    Jan 2009
    Bournemouth
    I have A4 2.5 TDi Avant and I am having trouble starting the car, it starts first time from cold then when it is warm is starts after about 10 to 15 seconds. The glow plug light starts flashing when it is warm. I would be greatfull for any advice I have also changed the brake light switch. My biggest fear is it maybe the fuel pump.
  2. Re: A4 2.5TDi hard to start
    Jan 2009
    towcester northants
    get diag test done first
    then report findings
  3. Re: A4 2.5TDi hard to start
    Jul 2008
    Bristol
    I had the same problem with my car and still do. I was told by a professional specialist, that it could be the faulty temp gauge which was done by a dodgy speciaist.
    In my case it was both, either the temp sense or something to do with the immobiliser. Couldnt get it done cause of job loss, so will get it fixed next month.
    However, I too have doubts that it could be the fuel pump.
  4. Re: A4 2.5TDi hard to start
    Jan 2009
    Bournemouth
    Have had car tested and it has 2 codes which are 01441 and 01442 the guy is a VW Audi specialist but could not really give me an idea of what to do so any help will be much appreceiated.
  5. Re: A4 2.5TDi hard to start
    Jan 2009
    towcester northants
    both codes point to an EGR valve fault
    p01441 is EGR valve circuit open/short circuit to ground
    p01442 is EGR valve position sensor signal too high
    you will need to check the EGR system
    this can be done via diag tool 1552 or vag com with use of wiring diagrams
    it sounds to me the specialist was reluctant to either fix or give info
    you are a bit far away to help in person but you can call me for info 07711 523638
  1. A4 wont start, and, and, and.
    By vma99r in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 11:32 AM
  2. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  3. a4 2.5tdi cut out and wont start
    By timlumsden in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-12-2007, 10:02 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
