Thread: ESP Fault light
  1. ESP Fault light
    May 2008
    Hi All,
    I have an A4 2001 2.0 Multitronic. The ESP light has started coming on after about two miles driving. The first couple of days it happened the engine would seem to restrict power for a second or two then would kick back in. This appears to have stopped now. I cannot switch light of once activated until engine turned off. Then light will clear until driven for the same amount of time. I have read previous forums stating things like rear brakes pad being replaced and faulty break lights. I had my rear discs and pads done about a month ago and no issues have happened since then. I will check rear brake lights. I did swap a blown bulb a few weeks ago but I cannot imagine a bulb could trip the ESP or can it? Any ideas?
  2. Re: ESP Fault light
    Jul 2008
    Wales
    Could be abs sensor, have you had the codes read? a friend of mine had this problem after he chiped the engine...
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. ESP fault light..........air bags?
    By mowjoe in forum Beetle 2000-
    Last Post: 17-09-2009, 09:48 PM
  4. Polo brake light switch
    By mark smith1951 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-01-2008, 05:55 PM
  5. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
