Thread: flat spot mk4 tdi 130
Results 1 to 10 of 11
  1. flat spot mk4 tdi 130
    Mar 2009
    hello to all. i have a problem on my beloved gt 130tdi. had the car for about 18months now but in the last few months a flat spot has developed. normally you can feel the turbo comming in at about 1500rpm then really kicking in around 1800+, but now its REALLY flat until over 2000rpm. this only happens for the first 5mins or so of driving when suddenly the car is back to normal! doesnt seem to matter if the engine is hot or cold. if i leave the car to go into the shop or something and get back in then its flat again. its like a torque tug of war with my emotions lol. please help??? many thnaks
    ash
  2. Re: flat spot mk4 tdi 130
    2005 Post(s)
    Take it to someone with fault code reading equipment, it will probably give code 17965, overboost.
  3. Re: flat spot mk4 tdi 130
    Mar 2009
    thanks for that. If i got that code then what woul be the next course of action to correct the problem?
    thanks for your quick reply
    ash
  4. Re: flat spot mk4 tdi 130
    2005 Post(s)
    Usually it means the turbo is clogged with carbon and needs cleaning which can be done chemically although this is not always successful and the best way is to remove, strip and clean the turbo. Occasionally it will be down to a faulty vane actuator but this is quite hard to diagnose with the turbo on the car. If this code is stored, the operation of the system needs to be check using the diagnostic computer in Basic Setting 04, Main Group 011 and the operation of the actuator observed. If it is moving freely the problem is a build up of carbon internally, if it does not move it may be solid with carbon or have a failed actuator. Very occasionally 17965 is down to a failed Air Mass Meter but I have only seen this once.
  5. Re: flat spot mk4 tdi 130
    Mar 2009
    thanks very much for your help, i will take the car to have the code read at some point then let u know
    cheers
    ash
  6. Re: flat spot mk4 tdi 130
    Mar 2009
    hi again. any one know how to chemicaly clean out the turbo as crasher said in the previous reply? thourght id try it first if it was just a matter of putting some additive into my tank. any advice appreciated. cheers
    ash
  1. golf Mk4 GT TDI 130 air leak / limp mode
    By leemasiuk in forum Golf MK4 - 1999 - 2004
    Last Post: 11-01-2008, 05:26 PM
  2. Mk4 Golf (ASZ - 130 bhp TDI) Timing Belt Issues
    By gavbarlow in forum Golf MK4 - 1999 - 2004
    Last Post: 05-02-2007, 01:12 PM
  3. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
