Thread: Passat 2.0l Petrol (130) : Oil in air intake and intermittent misfire
  1. Passat 2.0l Petrol (130) : Oil in air intake and intermittent misfire
    Coventry
    Hi all,
    My 2002 has been misfiring for a while intermittently in multiple cylinders. Coil packs, spark plugs and the wire harness to the coil plugs have all been replaced but the misfiring continues. I removed the air intake hose to see if the throttle has been blocked, which appears ok , but I noticed a lot of oil in the hose. Is this normal? If not where could this oil be coming rom and how to stop it? Does anyone think this could be the cause of misfire?
    Thanks,
    Zen
  2. Re: Passat 2.0l Petrol (130) : Oil in air intake and intermittent misfire
    134 Post(s)
    2022 Post(s)
    What is your engine code and have you had a fault code read done?
  3. Re: Passat 2.0l Petrol (130) : Oil in air intake and intermittent misfire
    Coventry
    Crasher,
    The engine code is: 3B0 907 557 R
    The latest fault code is (one of among many, becaue it got cleared several times before):
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16685 - Cylinder 1: Misfire Detected
    P0301 - 001 - Upper Limit Exceeded
    16686 - Cylinder 2: Misfire Detected
    P0302 - 001 - Upper Limit Exceeded
    Thanks,
    Zen
  4. Re: Passat 2.0l Petrol (130) : Oil in air intake and intermittent misfire
    134 Post(s)
    2022 Post(s)
    3B0 907 557 R is the engine control unit number but from that I can see your engine code is ALT.
    Carefully check the breather tube to the bleeder valve and the air inlet tube for any signs of splitting. The lower section is very awkward to get at to examine without removing it.
  1. 1996 A4 TDI 110 - Intermittent loss of turbo
    By jb1978 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-07-2011, 03:30 PM
  2. Intermittent fault with ABS
    By davedru in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2009, 11:48 AM
  3. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
  4. Replies: 9
    Last Post: 19-01-2008, 07:40 PM
  5. (Mult) System too Lean - 17536 - P1128
    By dm.A4.B5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2007, 08:35 PM
