Thread: ABS fault.
Results 1 to 8 of 8
  1. ABS fault.
    May 2009
    Leeds
    Hi everyone,
    the ABS light has been coming on in my 98 Sharan 1.9 tdi for some time now. I code read it and got the following error
    01276 ABS Hydraulic Pump (V64)
    16-10 Signal Outside Specification Intermittent.
    I had a look at the CV rings etc and new that the front offside ring was broken and the sensor was damaged so when it went in for its MOT they replaced those and passed the car. Have got the car back and I am still getting the same code so is it a case that another sensor has failed and if so why isn't VAG Com showing it or is it likely to be something else.
    Thanks for any help.
  2. Re: ABS fault.
    Jan 2009
    towcester northants
    sounds like the abs pump
  3. Re: ABS fault.
    May 2009
    Leeds
    As you can imagine, I was hoping to hear that it might be something cheap and simple to fix. Do you know how I can test the pump to see if it has failed before I start trying to change the unit?
  4. Re: ABS fault.
    Jan 2009
    towcester northants
    look on internet there are several places that recondition abs unit at a resonable price
  5. Re: ABS fault.
    May 2009
    Leeds
    many thanks, will give it a go.
  6. Re: ABS fault.
    Norfolk
    Are you worried about the fault code or the light being on. If the light is on you are stuck for MOT but if it's just a fault code you can probably ignore it. An error code on these pumps doesn't have to mean the unit is faulty it just means it's outside the ecu spec.
  7. Re: ABS fault.
    May 2009
    Leeds
    The ABS light comes on when I get up to approx 15-18 mph and then flags up the fault code. All the sensors and ABS rings are ok so I presume it must be something else. They did pass it for the MOT as they said whilst it was being tested the light did not come on so they can't have gone fast enough to trigger it.
  8. Re: ABS fault.
    Norfolk
    Have a good look at your tyres. Check all tyres are same size (i know it sounds silly) and check for damage. Ultimately you may have to replace abs module. Recon units are much cheaper these days, you don't need to buy new.
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. MK 3 Gti 16v Fault Code - ABS Problem
    By dravidham in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
