Thread: Air-con
  1. Air-con
    Nov 2008
    With the recent heat wave I have been using the air-con in my B6 a lot. Now my question is: how do I know if it needs a re-charge? It's a 2004 model and as far as I know hasn't ever been done. It's cold when on low, but not as cold as I think it could be. Any help gratefully received!
  2. Re: Air-con
    Southern County Softy
    20 Post(s)
    Air con should be serviced every couple years.
    Contact a specialist.
    They should suck the gas out, hold the system in vacuum to check for leaks, add some lube oil then re-gass with the correct amount of gas.
    A4 2.5 tdi QS (mapped)
  1. Air Con Playing Up?
    By stu22uk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-03-2011, 09:48 AM
  2. Golf Air Con Not Cooling
    By colinmchardy in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2009, 12:51 AM
  3. S4 Air con challenge Help please
    By Audinzs4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2009, 12:02 AM
  4. Air con compressor problem
    By rhysdavies in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-05-2008, 11:48 AM
  5. Air con making rear footwell wet?
    By Dfardon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2008, 10:52 AM
