Thread: Glow Plugs on a '94 Golf TD
  1. Glow Plugs on a '94 Golf TD
    Jan 2006
    Leigh
    How often do they need changing? The cars done just over 135,000 miles. I've owned the car for over a year now and done over 25,000 miles and they havn't been changed in my ownership. I can't see any reords of them being replaced in the service book either. Although the car is running fine, I was just curious as to whether I should change them. Would the car run any better with new ones? And how hard are they to change?
    '99 B5 Passat 1.8 T 20v Sport
    Canada
    Glow plugs only need to be changed if they have failed, a good indicator is when you start and the engine rattles more then normal and smokes. I have only had to replace one on a diesel citreon I have.
    Glow plugs are very reliable these days, i went through 3 sets on my transporter 1600 diesel (1983) when i had it
    Rob
    Jan 2006
    Leigh
    Thats ok then, I think I'll leave them alone. Although it does smoke a bit and rattles if I don't put the choke on from cold start up, but thats understandable.
    Apr 2007
    They are a bitch to change, i would leave em unless they were gagging for it.
    Canada
    Quote Originally Posted by A350BHPQUATTRO View Post
    I second that! you can test by using a multimeter. disconect the power connection to each plug, then test the resistance between the probe and ground. if its around 1ohm then its ok.
    Rob
  1. MK3 Golf TDI Glow Plug starting issues
    By 27motorhead in forum Golf MK3 - 1993 - 1999
    Last Post: 01-10-2010, 12:02 AM
  2. Glow plugs dont switch on
    By ghee60 in forum 80 - 90
    Last Post: 26-08-2009, 12:02 PM
  3. Mk4 Golf GTi 2.0 (115) Recommended spark plugs
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 16-05-2007, 12:54 AM
  4. GOLF TDi glow plug light
    By glynTDi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 09:40 AM
  5. changing glow plugs Golf 3
    By eribar in forum Golf MK3 - 1993 - 1999
    Last Post: 30-03-2007, 04:45 PM
