Thread: oil in spark plug ports
  1. oil in spark plug ports
    Jul 2008
    hi all,
    went to change the spark plugs on my 1.8T B6, but before taking the plugs out i noticed that oil was sitting in the port of the plugs. it seems to be leaking from the rocker cover gasket. Is it this rocker cover gasket or could something else be causing over pressure causing it to leak.
    Also which spark plugs fit the 1.8T, went to the audi ******** and they gave me ones with a single ground and the ones in the car are triple ground. both are genuine audi parts.
    2001 AUDI A4 1.8T SPORT
  2. Re: oil in spark plug ports
    Jan 2009
    towcester northants
    change the cam cover gasket
    the spark plugs can be either depending on model year
  3. Re: oil in spark plug ports
    paul20v Guest
    single electrodes are fine ,
    triple electrodes were just designed to extend the life of the plugs but in honesty dont make that much difference if any .
  4. Re: oil in spark plug ports
    Jul 2008
    is it better to go for a genuine one or are there better aftermarket ones out there?
  5. Re: oil in spark plug ports
    paul20v Guest
    I personally stick with bosch as i have found them to be best over the last 20 years of audi owner ship ,
    for service life and reliability.
  1. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  2. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  3. Answers from an oil expert...
    Last Post: 20-01-2008, 05:30 PM
  4. Answers From The Oil Expert Part 2
    Last Post: 22-10-2007, 08:30 AM
