Thread: Glow plugs dont switch on
  1. Glow plugs dont switch on
    Mar 2007
    J27 M5
    Well I have a problem, The glow plugs wont switch on when the temperature sensor on the side of the block is plugged in. If I unplug the sensor the glowplugs work.
    I have replaced the sensor and the glowplug relay, and checked the terminals in the fuse box. They are all fine and pass a current if the sensor is plugged in or not.
    The glow plug light on the dash comes on when the sensor is unplugged and doesnt when its plugged in.
    So then everyone whats broken?
    Things I do : Engine Swaps, Modifications, Car Audio Installs
    Things I dont do : Diesels
  2. Re: Glow plugs dont switch on
    Aug 2009
    omagh
    did you get to the bottom of the problem with the glow plugs, as i have the same problem.
  3. Re: Glow plugs dont switch on
    Dec 2007
    8 Post(s)
    Quote Originally Posted by ghee60 View Post
    I dont think anything is broken. As far as I know the glow plugs do not get a signal to operate until the temperature is much lower than at present
    When the temperature drops to about six degrees they may operate.
    They must get their signal through the blue temp sensor on side of engine.
  4. Re: Glow plugs dont switch on
    Aug 2009
    omagh
    yes i no, but even in the winter time it jst comes on and off straight away. i tested the temp sensor and it is ok, i even bought a new one and placed it in cold water, still no good.
    realli starting to get to me......
  5. Re: Glow plugs dont switch on
    Dec 2007
    8 Post(s)
    Quote Originally Posted by omore2000 View Post
    If its any help I did have your problem one winter and it was sorted by a new blue sensor. ( light stayed on for a longer period with new unit)I am not sure what keeps the glow plugs on for the predetermined time period but I expect it is a relay so maybe it may be faulty, Also check the metal fuse strip and glow plugs
  1. Glow Plugs on a '94 Golf TD
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 08:01 PM
  2. changing glow plugs Golf 3
    By eribar in forum Golf MK3 - 1993 - 1999
    Last Post: 30-03-2007, 04:45 PM
  3. HELP PLEASE..Polo Gti lowering kit? I dont know what 2 buy.
    By joseygrosey in forum Polo - Derby - Lupo - Fox
    Last Post: 07-03-2007, 08:35 PM
  4. Interior Lights dont work
    By GrahamO in forum Chat - Completely Off Topic
    Last Post: 23-02-2007, 11:45 PM
  5. oh my god dont think this is good
    By garying3980 in forum Passat - Archive Topics
    Last Post: 18-02-2007, 01:24 PM
