Thread: Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
  1. Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    May 2009
    kent
    hi there recently rigged my 1.8t bora up to a dionostic machine as the engine managment light was showing. the result of this was fault code 17544 which i understand mean the fuel is running to lean.
    can anyone tell me what could be causing this.
    also i had the water pump changed last week is the sensor for this close and is it pos the sensor may have been knocked while this was being changed?
    any help will be hugly helpful. . .
  2. Re: Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    131 Post(s)
    1975 Post(s)
    I often find that is due to a pipe under the inlet manifold splitting. It runs from the crankcase breather T piece to the inlet manifold, and the main breather pipe is also prone to splitting. No it can’t be anything to do with the water pump job. The pipe under the manifold is extremely difficult to get at, you have to remove the front valve tray from the inlet manifold to be even able to get your hands on it, that is assuming you have an AUM engine.
  3. Re: Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    May 2009
    kent
    thanks for that. my engine is AUQ. would there be varst amount of diffrence?
  4. Re: Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    131 Post(s)
    1975 Post(s)
    The AUM and AUQ are absolutely identical in every way, the only difference is in the ECU software.
  5. Re: Long Term Fuel Trim Add Fuel, Bank1 System too Lean. (17544)
    May 2009
    kent
    ok thanks very much pal. i'l get it loooked into.
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Replies: 0
    Last Post: 14-11-2007, 10:16 PM
  3. A4 Fuel problem
    By daz in forum Archive posts
    Last Post: 03-09-2005, 10:45 PM
  4. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
