Thread: 2005 TDI Caddy Van
  1. 2005 TDI Caddy Van
    Jun 2009
    Ashbourne UK
    Hey there guys, i currently own a VW 2005 TDI CADDY VAN and have some starting issues with it. When engine is cold it fires into life pretty much ok with only a slight hesitation sometimes, but when its just been used (engine warm) it finds it really hard to kick into life although at the moment it will eventually start. Battery and starter motor ok it turns over at ease and when engine runs at any tempreture there seems to be no problems what so ever! Idles smoothley and revs are responsive.
    Any ideas folks?
  2. Re: 2005 TDI Caddy Van
    Jul 2007
    Cheshire, or my A6
    Can you see any bubbles in the fuel lines? This would point to air being stuck in there.
    I've got this problem with my Skoda, it has got air in the fuel lines, and when warm it can take as long as about 8 seconds to start. I'm just trying to work out where the air is coming from, although I've not looked into it too much just yet. Starts perfect from cold.
  3. Re: 2005 TDI Caddy Van
    Jun 2009
    Ashbourne UK
    Yeah im not sure i can find any air in the fuel?? Any other ideas?
  4. Re: 2005 TDI Caddy Van
    Jun 2009
    Ashbourne UK
    Have you managed to find where the air is getting in
  5. Re: 2005 TDI Caddy Van
    Jul 2007
    Cheshire, or my A6
    No, I've not found the time to look at mine yet.
    I should have thought, you might not have clear/transparent fuel lines, making air in the fuel more difficult to spot.
  1. Gearbox noise 2005 Passat tdi
    By treedown in forum New Member Introductions
    Last Post: 18-02-2008, 03:33 PM
  2. Volkswagen Set To Unveil Versatile New Caddy Maxi Life
    Last Post: 08-09-2007, 08:07 PM
  3. 53 plate caddy van rear door problem
    By stormtrooper in forum The Commercial Range
    Last Post: 14-07-2007, 02:49 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
