Thread: moving the lock from one glove box to another
Results 1 to 8 of 8
  1. moving the lock from one glove box to another
    west midlands
    Hi, i recently replaced my glove box but need to change over the locks.
    Can anyone please advise me on how to do this.
    Thank You
    'AUDI A4 - 2003 - 1.9TDI 130 - B6 SALOON'
    'AUDI A4 - 2008 - 2.0TDI 143 - B8 SALOON'
  2. Re: moving the lock from one glove box to another
    Remove the glove box
    Open lid of glove box.
    Slacken off bolt of handle on lid side.
    Pull handle out of glove box lid.
    Press out pin and take out lock
  3. Re: moving the lock from one glove box to another
    west midlands
    thank you, i will try that first thing.
  4. Re: moving the lock from one glove box to another
    Sep 2008
    London
    i am in need of the left side hinge for my glovebox as mine has broken do you have this spare?
    thanks
    Audi A4 2004 1.8T S-line (190) Multitronic Misano Red
    _______________________________
    Retrofitted: cruise control/(Hazzydays)
  5. Re: moving the lock from one glove box to another
    west midlands
    Thank you Kennedy, that worked a treat.
  6. Re: moving the lock from one glove box to another
    west midlands
    Hi mr meeks, the hinges are completely shot on the old glove box.
  7. Re: moving the lock from one glove box to another
    Dec 2008
    I recently replaced lock on my glovebox. No need to remove the whole box for this job. I'll admit the access for the retaininmg screw on drivers side of glovebox door is akward to get at. I used a power drill bit holder with the torx bit in it and rotated it using a small spanner while applying pressure to the bit using a finger pusing pon end of bit holder. You can't see the screw so you are locating the torx into the screw blind but once there easy peasy. Of course taking the whole box out does give advantage of being able to lube hinges etc
  8. Re: moving the lock from one glove box to another
    Mar 2009
    Brighton
    Quote Originally Posted by BMurr View Post
    Although it only takes 2 minutes to remove and about 5 minutes to re-fit. That's the time it would take me to find the bits required to do the job with the glove box in situ.
    Besides, I found it much easier to replace the lid with the whole thing removed and on the bench.
    Horses for courses I guess.
    Embisix
    Current: 2010 A4 2.0TDI Quattro S line Executive Saloon (Sepang Blue Pearl)
    Previous: 2004 A4 Avant 1.9 TDI Quattro Sport (Atlas Grey)
    Previous: A string of (mainly) DOHC VTEC flavoured Hondas
  1. Replies: 3
    Last Post: 12-06-2009, 08:12 PM
  2. How To remove inner door card and get to lock
    By adzul in forum Golf MK4 - 1999 - 2004
    Last Post: 26-05-2009, 01:58 AM
  3. Glove Box Lid Won't Shut
    By coeur in forum Golf MK4 - 1999 - 2004
    Last Post: 07-05-2009, 12:54 PM
  4. Glove Box Light A4
    By STONEWALL in forum Chat - Anything with wheels
    Last Post: 05-07-2008, 07:37 PM
  5. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
