Thread: t5 t30 130hp alternator replacement
  1. t5 t30 130hp alternator replacement
    Jun 2009
    plymouth
    Hi there i need to replace the alternator on my t5 its the 130hp 2.5 turbo
    and was wondering if anyone had any tips or has done one as i had a quick look today and removed the sump guard and it looks a bit of a pig of a job. any advice would be gratefull thanks
  2. Re: t5 t30 130hp alternator replacement
    Nov 2008
    folkestone.kent
    correct you will have to take the front off,make sure its not just the coupling or worse the drive shaft not turning the alternator ....
  3. Re: t5 t30 130hp alternator replacement
    Jun 2009
    plymouth
    thanks for your help, turned out to be something completly different in the end which has now been sorted alot easier and cheaper
  4. Re: t5 t30 130hp alternator replacement
    Nov 2008
    folkestone.kent
    what was that ?
  1. T5 hard to start from cold?
    By Scrotum Head in forum The Commercial Range
    Last Post: 11-01-2016, 11:39 PM
  2. T5 2.5 130 water coolant loss and oil light.
    By hocks172 in forum The Commercial Range
    Last Post: 06-10-2010, 07:09 PM
  3. Vw 2005 2.5 Tdi T5 Transporter
    By bigtee in forum The Commercial Range
    Last Post: 25-06-2010, 03:01 PM
  4. Please Help rattle coming from front of t5 t30 lwb 55
    By candlemaker in forum The Commercial Range
    Last Post: 31-05-2009, 10:39 PM
  5. vw t5 engine and stereo questions
    By tilex in forum The Commercial Range
    Last Post: 30-04-2008, 08:50 PM
