I've recently been encountering some major faults on my A4 2.0 tdi SE. Below is the list of problems and history of the vehicle.
Dec 2005 - purchased from Stockport Audi (former courtesy car with 13,000 on the clock. Full service and new tyres
Full dealer servicing until June 2009.
Collision with joyrider in 2008 resulting in front end damage from drivers side and 8 week repair. At time of impact all warning lights came on and car was driven by police recovery vehicle onto a low loader. Airbags weren't deployed which I found strange.
Vehicle didn't feel the same after repair but was road tested by independent assesor retained by my solicitor.
Cam belt done at 52,000 by Stockport Audi.
May 2009 - started feeling serious judder on car when accelerating through 4th, 5th into 6th.
Researched and called several independent specialists. All hinted it was the clutch and dual mass flywheel.
I booked it into the Audi dealership in the hope that if it was the DMF then I may get some sort of contribution as it's a known fault that they don't like to admit.
In short they kept the car for two days, forgot to do the MOT that it was also booked in for and then claimed it was done, and couldn't find the fault - even though the tech commented on the service report he suspected a flywheel fault.
Since then I had the cluth and DMF replaced by an independent plus a full service and brake bleed. Guess what... the fault reappeared immediately.
So.. below is the fault:
- Sluggish ignition
- Lumpy idle
- Fine through 1st to 3rd - though doesn't feel as smooth as it once did
- Fault occurs at 60-70 mph e.g. on motorway - power flatlines, chugs and I can hear a grating/clashing sound. Can power through it to 80 and engine seems fine if a little lumpy/uneven ish.
- One off fault noted today - car lost power at 70 on cruise control. Foot to the floor and little increase in power, faltered on incline and speed dropped to 60mph. Revs remained constant - cleared after 1hr stand and seemed okay but main fault occured again.
- Gear stick judders around like crazy in 4-6th when accelerating hard
- On previous Audi inspection - fuel injector seals noted as poss. replacement.
Any help really appreciated as I am at the end of my tehter and £800 down after clutch/DMF and service bill.
Barefootin
