Thread: Front Cigarrette Lighter not working - not the fuse
Results 1 to 10 of 18
  1. Exclamation Front Cigarrette Lighter not working - not the fuse
    Jun 2009
    Tonbridge, Kent, UK
    Hi all
    Just noticed that my front cigarrette lighter isn't working, doesn't light the lighter (doesn't stay down) and doesn't charge my sat nav plug. However, the one in the boot does.
    CHecked fuses, swapped them around and all ok. any ideas?
    thank you!
    Pete
    vw golf mk5, 2005 1.9 tdi se
  2. Re: Front Cigarrette Lighter not working - not the fuse
    Dec 2006
    I have got thew same issue and never got around to fixing it,
    I will have a look through some posts as i did post it and got some answrs, plus i think i have some PDF documents which i will upload.
    Then.. hopefully we will be able to fix the issue once we get some ideas on the fault.
    cheers
    Rick
  3. Re: Front Cigarrette Lighter not working - not the fuse
    Jun 2009
    Tonbridge, Kent, UK
    ah cheers Rick, that'll be great. i got the car last week, ex-fleet, and can't believe the last owner didn't use a sat nav.
    look forward to seeing some fixes!
  4. Re: Front Cigarrette Lighter not working - not the fuse
    Jun 2009
    Tonbridge, Kent, UK
    just checked the connections underneath the ash tray and they're all ok, but tested and theres no live feed. I thought the front and back cigarette lighters ran off the same fuse? (42 in fuse box by drivers door http://www.golfmkv.com/forums/showth...highlight=fuse)
  5. Re: Front Cigarrette Lighter not working - not the fuse
    They do share the same fuse,does the rear lighter work?if not check if you have power on the fuse 42.
  6. Re: Front Cigarrette Lighter not working - not the fuse
    Jun 2009
    Tonbridge, Kent, UK
    Quote Originally Posted by kenney View Post
    hi, yeah the rear lighter works fine. have swapped fuses around but nothing.
  7. Re: Front Cigarrette Lighter not working - not the fuse
    Turn the side lights on and check the cigarette lighter illumination bulb,this is to check if the earth on the lighter is ok
  8. Re: Front Cigarrette Lighter not working - not the fuse
    Jun 2009
    Tonbridge, Kent, UK
    yup, the orange ring around it lights up
  9. Re: Front Cigarrette Lighter not working - not the fuse
    Dec 2006
    Quote Originally Posted by petesaysblimey View Post
    Same here........
  10. Re: Front Cigarrette Lighter not working - not the fuse
    I would say then the fault is a connection in the main wiring harness this is a soldered joint,and don't ask me where it is,i haven't a clue,Rather than split the harness,i would run a new wire from the rear lighter.
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. Heated windscreen problem
    By Nautilus in forum Touran - Sharan - Caravelle
    Last Post: 31-12-2008, 10:27 AM
  3. Front short light not working
    By Apocalypso in forum Chat - Anything with wheels
    Last Post: 01-05-2008, 04:43 PM
  4. Sharan Lighter not working
    By Ferd in forum Touran - Sharan - Caravelle
    Last Post: 26-08-2007, 09:25 AM
  5. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
