Thread: T4 Rear Springs
  1. T4 Rear Springs
    Margate,Kent
    I have owned my 2000 T4 since 90k & it has now done 207k - in that time I have had two sets of rear springs - they break near the bottom of the "pigtail".
    It's normal load is about 1/2 > 3/4 it's full load.
    Anyone know of any heavier duty springs that I can fit or will I just have to put up with it evert 50k or so ?
    Thanks in advance.
    take care & enjoy life
    Brian Considine
  2. Re: T4 Rear Springs
    stourbridge,west midlands
    I did see some on ebay once that were advertised as heavier duty springs, It said they were VAG springs and they did look heavy duty but saying that so do mine on my 1200 T4.
    There might well be uprated springs available from VW so it might be worth calling your local van centre to see if any are available.
    If your van is an 800 or 1000 you could always upgrade to 1200 springs to cope better with the weight.
    By the way my near side rear spring broke in the same place as yours so probably a common place for them to snap.
    Matt.
  3. Re: T4 Rear Springs
    Order the springs for an ambulance,they are heavy duty
  4. Re: T4 Rear Springs
    Nov 2008
    folkestone.kent
    very common failure we do looooooooooooooooooads of them the good thing about fitting them is it only takes 10mins a side !!
  5. Re: T4 Rear Springs
    Margate,Kent
    Thanks guys - maybe if I can get a set of the ambulance one kenney suggested VAGMAN can fit them for me ?
    Any chance of the part number please kenney ? - thanks in advance.
    Other people have told me that this is a common fault - seems to be about the only weak spot to these otherwise bombproof vans.
    Brian Considine
  6. Re: T4 Rear Springs
    Nov 2008
    folkestone.kent
    yeah thats no problem .....what do the others do to change them i know what i do ?
  7. Re: T4 Rear Springs
    Margate,Kent
    They have always been done with a service so diffecult to tell the actual cost !
    Brian Considine
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Ride height higher on left rear after replacing springs
    By a4Matt_tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-05-2009, 07:23 PM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. How does the Quattro system work?
