Thread: Coolant leak
Results 1 to 10 of 14
  1. Coolant leak
    Jun 2009
    Leeds UK
    I have an audi A4 1.8 t and it has a coolant leak. I noticed some fluid dripping from under the engine area after a journey so i put some paper under which indicated it was coolant by the colour, it only leaks for a max of 2 mins and is a slow drip? i think i can hear it drippin on something else and then the ground. it doesn't loose a great deal but i'm guessing its not meant to at all! can't see anythin in the engine bay but it is pretty cramped in there The car drives okay and heat temp is okay as well as cc.
    Can anyone help with any tips please? or answers to what it is. btw i have no clue about this stuff
    cheers
  2. Re: Coolant leak
    Jan 2009
    towcester northants
    rads are a problem
  3. Re: Coolant leak
    Haven't had this issue myself, but it might be worth looking at the water pump, if it is a bit loose it's a sign its on its way out, water could be coming from there.
  4. Re: Coolant leak
    Jul 2007
    somerset
    8 Post(s)
    Also a place that is starting to become a common problem with coolant leaks is the plastic housing at the rear of the engine that holds the temp sensors in. It has a habbit of breaking up and starts to leak.
    You don't say where the leak is, but if its towards the rear of the engine compartment check out this plastic part. P.S genuine audi replacement around £10 but pretty fiddly to do.
  5. Re: Coolant leak
    Jun 2009
    Leeds UK
    Thanks for ya reply guys, in terms of where the leak is it is more towards the front area kinda in line with where the steering rack(?) is. near a thin strip of metal which seems to do nothing under the front part of the engine area? if it drives fine is it likely to be expensive.... should i start saving now!?
  6. Re: Coolant leak
    Jan 2009
    Yeovil, Somerset
    I had what sounds like a very similar coolant leak and detected it by looking down by the exhaust manifold to the rear of the engine towards the bulkhead, there was a witness of coolent on a ledge of the engine block. If you can, try to get your hand around the area and see if you can locate anything?
  7. Re: Coolant leak
    Southern County Softy
    20 Post(s)
    You sure its losing coolant and not the aircon drain ?
    A4 2.5 tdi QS (mapped)
  8. Re: Coolant leak
    Jun 2009
    Leeds UK
    I'll try and have a look in that area and get back to you. yeah it's coolant because i have to top it up almost every other day beacuse it drops a couple of mm every few days. I do Find it weird how sometimes it leaks and sometimes it doesn't? my driving style doesn't really change
  9. Re: Coolant leak
    Nov 2008
    Also check the plastic bleed screw on the coolant tube under the plastic engine cover
    when i was cleanig my engine i knocked of the head of this plastic screw leaving only
    the body of the screw in the coolant tube.These screw's are prone to failing.This as also been covered on an audi forum...So check yours these screw's are about £1.70 from main dealer
  10. Re: Coolant leak
    Quote Originally Posted by CMD View Post
    I'm sure you can get this cheaper on eBay!
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. A3 coolant leak
    By hensojm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-11-2009, 12:22 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Trans oil or coolant leak....any help?
    By Daza-1979 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2007, 11:53 PM
  5. 2001 Passt TDi Coolant leak
    By g4ryhunt in forum Passat - Archive Topics
    Last Post: 15-11-2006, 07:07 PM
