Thread: Mk3 8valve handbrake light on permantly
Results 1 to 8 of 8
  1. Mk3 8valve handbrake light on permantly
    Have just bought a MK3 8 Valve after many years away from the MK3 scene.The handbrake light is permantly even thought the handbrake is off!
    Could this be the handbrake light switch? If so any idea as to where it is and how do i adjust it?
  2. Re: Mk3 8valve handbrake light on permantly
    Mar 2008
    High Wycombe
    The handbrake switch is under the handbrake. If you take off the centre console (rear part), you should be able to see it. See if the switch is pushed down when the handbrake is off. Try pushing it down manually to see if it works.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Mk3 8valve handbrake light on permantly
    Thanks,I'll have a look when i get time.
  4. Re: Mk3 8valve handbrake light on permantly
    131 Post(s)
    1979 Post(s)
    It is also the brake fluid level warning, check the level.
  5. Re: Mk3 8valve handbrake light on permantly
    Excellent answer,thanks Crasher.I forgot that this was the warning on the MK3'S.I'll check this first the the handbrake if this fails to cure it!
  6. Re: Mk3 8valve handbrake light on permantly
    Have checked the brake fluid and all is fine there.Took the centre console off and disconnected the handbrake light sitch and the light was still on even though i'd disconnected it!! I did press down the button which should make the light go out but that didn't do anything either.
    Am wondering if it's something to do with the top on the brake fluid resevoir which has the electrical connector going to it.?
    Any more help and ideas would be good
  7. Re: Mk3 8valve handbrake light on permantly
    131 Post(s)
    1979 Post(s)
    Disconnect the level sender plug.
  8. Re: Mk3 8valve handbrake light on permantly
    Okey doke will give it a whirl.Cheers
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  3. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  4. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  5. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
