Thread: Airlock Perhaps?
  1. Airlock Perhaps?
    Jun 2009
    Model GOLF RYDER (MK3)
    Engine Size 1391 cc
    Engine Model ABD
    I need a little help.
    I've replaced the thermostat on the above car and think I might have an airlock.
    I did not empty the coolant as perhaps you should (just removed the hose at the thermostat housing) and have refilled the coolant to the correct levels. All runs fine apart from the fact that the coolant runs over the bottle when the fan cuts in and the hot blowers in the car are just pushing out cold air.
    I've tried running the car with the coolant tank cap off and have squeezed the hoses, but this has not helped.
    Any help with this would be appreciated.
  2. Re: Airlock Perhaps?
    134 Post(s)
    2008 Post(s)
    Sounds like a failed water pump or faulty coolant cap O ring. Why did you change the thermostat?
  3. Re: Airlock Perhaps?
    Jun 2009
    Sorry should have said that I have replaced the thermostat after I noticed a slight leak from the housing. Alls fine now, no leaks etc.
    Before doing so I could have hot air blowing in the car, as well as cool air. The water pump is working as it is pumping coolant around. The coolant cap 'O' ring is fine as well.
    I refilled the coolant and ran the car up to temperature. This caused the coolant to run out of the expansion thingy on the coolant bottle and the coolant level was then lower than the coolant bottle. So I refilled again and left the coolant cap off, ran the engine and squeezed the hose's, but with no luck as the problem happened again. One thing I did notice is that in the car when selecting hot on the blowers, it was only blowing cold.
    That's what made me think it might be a possible airlock in the matrix.
    EDIT: Could be right about the 'O' ring. Not sure about the fact that you cannot have hot air in the car.
  4. Re: Airlock Perhaps?
    134 Post(s)
    2008 Post(s)
    They don't tend to get air locks.
  5. Re: Airlock Perhaps?
    Jun 2009
    Ok and cheers. I'll have a look at the 'O' ring though.
  6. Re: Airlock Perhaps?
    Jun 2009
    Quote Originally Posted by vr6dubeast View Post
    Thank you Crasher.
    It was the 'O' ring and looked exactly as the one in that picture you posted.
    Still got no hot air from the blowers, but its summer time (hmmmm)
    Once again thanks
  1. Please Help AIRLOCK ON 1.8t 20v AWT ENGINE
    By rosco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-09-2009, 07:37 PM
  2. Overheating
    By Phat_vento in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2008, 05:16 PM
  3. T4 2,4d 2000; airlock in fuel line, etc?
    By Black Angus in forum The Commercial Range
    Last Post: 25-02-2008, 05:38 PM
  4. Heater Airlock
    By Clevinger in forum Golf MK3 - 1993 - 1999
    Last Post: 05-02-2008, 01:00 PM
  5. Cold air all the time???
    By hampton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-04-2007, 10:03 AM
