Thread: dash clocks
  1. dash clocks
    Dec 2007
    any tops on removeing the clocks b7
  2. Re: dash clocks
    Jun 2008
    Marmitehampton
    Remove the small piece of plastic trim below the clocks and above the steering wheel by pulling gently. This will reveal two Torx screws, undo these and the clocks are released. Drop the steering wheel and extend it as far as it can. Now you can either remove the fuse box cover, reach in and push it out and then try and remove the two plugs on the rear (they have an arm that must be unclipped and opened in a similar manner to the Quadlok on the back of the radio). This is very fiddly and by far the easiest way if removing the clocks completely is to remove the trim under the steering wheel where the service book goes as there is far more room to get in...
    Hope this makes sense and helps...
    Is this your car? I thought you had a B6 cab, Bez?
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  3. Re: dash clocks
    Dec 2007
    Quote Originally Posted by Flakmunky View Post
    still got the cab but got a b7 2.0fsi t cos of the mway miles i do
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. Please Help 2 questions regarding changing clocks.
    By livehybrid in forum Golf MK3 - 1993 - 1999
    Last Post: 22-04-2009, 08:09 PM
  3. HELP NEEDED!!With Fitting Clocks!!
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2008, 01:54 PM
  4. Dash problems...still....gremlins, connectors what and where
    By 1.9 TDI Sharan in forum Touran - Sharan - Caravelle
    Last Post: 02-01-2008, 04:29 PM
  5. Help Needed With Dash Clocks!!
    By scoobyra in forum Archive posts
    Last Post: 29-04-2007, 08:31 PM
