Thread: Brake Servo
  1. Brake Servo
    Feb 2009
    i have removed the seal under bonnet and the plastic battery cover to try and locate the brae servo (passat b5 tdi 2003)
    what i need to know is what exactly does the brake servo look like as i am trying to locate the drain underneath it
    i know it is somewhere near the driver side bulkhead but not sure what it is exactly.
    been quoted £140 to clear all blockages at independants and fancy doing it myself to be honest
    im no mechanic obviously, but feel i can do this job
    cheers
    thank you
  2. Re: Brake Servo
    Mar 2009
    Have a look at THIS LINK as it seems you're cleaning out the drain holes.
    It's a good guide with pics. Mac
    I came in to this world with nothing and I've still got most of it left.
  3. Re: Brake Servo
    Feb 2009
    by removing the battery, can i get to the drain hole underneath the brake servo?
    i thought i had to do this seperately to the battery drain.
    another quick question...if i disconnect the battery, do i then have to use vag com after reconnecting???
    cheers
    thanks for earlier answer
  4. Re: Brake Servo
    Mar 2009
    Quote Originally Posted by passat130tdi View Post
    cheers
    Read through the link, it explains everything and with pics, very easy to understand. Mac
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. Polo/Lupo brake servo pipe.
    By westie383 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2008, 11:34 PM
  4. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
