Thread: TDI 6 SPEEDS....AVF vs ASZ
Results 1 to 10 of 14
  1. TDI 6 SPEEDS....AVF vs ASZ
    What are the differences in the AVF(TDI130 6 speed in passat) and ASZ engines(TDI130 6 speed in bora) apart from being connected to a different gearbox and 1 being transversed and the other length ways?
    I ask this because vw state that the passat gets to 60 quicker on paper (9.9) and the bora can only do it in 10.1. Also they state the passats top speed is 129mph and the boras is 127mph
    Doesnt make sense to me as the passat is a good bit heavier than the bora(prob 200kg) and they both have 130bhp and 310nm torks YET the passat is down as being quicker...
  2. Re: TDI 6 SPEEDS....AVF vs ASZ
    A 10er for anybody can answer the above question
  3. Re: TDI 6 SPEEDS....AVF vs ASZ
    Different ratios maybe. First gear may be shorter because a passat is heavier.
    Complete ( though possibly educated ) guess.
    Al
  4. Re: TDI 6 SPEEDS....AVF vs ASZ
    Ive driven i and it still has the same short first that the bora has... 10er still stands guys! any takers??
  5. Re: TDI 6 SPEEDS....AVF vs ASZ
    Mar 2009
    Gillingham Kent
    Passat probably does'nt lose as much bhp through the gearbox as the Bora & are wheel & tyre sizes the same if not that would also make a difference
  6. Re: TDI 6 SPEEDS....AVF vs ASZ
    Yeah maybe...Id give ya a fiver for that answer .... Dont ya just love a question where nobody knows the answer.... Even if it is a bit childish
    Oh the bora gets 16s as does the passat... A bigger tire would SLOW tthe car down ya know so the passat should be slower going by that anology...
    Are the AVF and the ASZ engines identical internally? Whats the difference beteen the 02m 6 speed gearbox the and passat 6 speed?
  7. Re: TDI 6 SPEEDS....AVF vs ASZ
    Mar 2009
    Gillingham Kent
    Will slow the acceleration down but should make it a bit more long legged on top end speed.
    Put the fiver in first charity box you come across
  8. Re: TDI 6 SPEEDS....AVF vs ASZ
    Chester-le-Street, United Kingdom
    Quote Originally Posted by pon View Post
    if a 16" wheel is rotating at 100rpm,we could assume that it would cover
    1600" per min.
    surely a 17" would cover 1700"
    and an 18" would cover 1800" in the same minute?
    does the larger wheel not make the car accelerate faster?
    can of worms,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  9. Re: TDI 6 SPEEDS....AVF vs ASZ
    Mar 2009
    Gillingham Kent
    It is a big can of worms.
    All down to different aspects wheel size, tyre size, bhp lost through the
    gearbox and gear ratios.
    Im sure someone will come along and be a proper smart alec and know the answer
  10. Re: TDI 6 SPEEDS....AVF vs ASZ
    Quote Originally Posted by STEWY L View Post
    1600" per min.
    can of worms,
    regards,
    stewy.
    actually they wouldn't travel the diameter,(16,17,or18)
    they would travel the circumference
    regards,
    stewy
    4th cog,--two to go
  1. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  2. Change from 5sp to 6sp
    By lowndsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2007, 08:14 PM
  3. New Audi A6 allroad quattro ready to tackle British soil
    Last Post: 05-04-2006, 08:13 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
