Thread: Axle Stands...
Results 1 to 10 of 10
  1. Axle Stands...
    S Wales
    ....I've never used them before, so where's the best place to put them? My haynes says at the jacking point with a 'suitable block of wood', but surely my jack will already be there..
  2. Re: Axle Stands...
    Tyldesley, Manchester, UK
    Most parts of the chassis will do.
    One German, Two Italian.
  3. Re: Axle Stands...
    Feb 2007
    Nottingham
    You'll see on the underside of the car a pronounced piece in the chassis/floorplan back from the seem like the one above, these are perfect for axle stands, oh and using a piece of cardboard will lower my oppinion of you.
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  4. Re: Axle Stands...
    May 2006
    Certainly wouldn't use the jacking points as these tend to be on a seam. If you lowered the car onto these, something would buckle. with possible damage to the cills.
    Best place is as MalcQV says. Look to locate under the sub frame/chassis.
  5. Re: Axle Stands...
    S Wales
    Cheers boys, thought using the jacking area would be a bit iffy.
    Secondly (even though I know 'in theory' it wont), would switching on the engine/turning my power steering be a problem whilst up on the axle stands?
    Again, i'm still learning so any sarcasm or abuse will be taken on the chin! haha
  6. Re: Axle Stands...
    Mar 2008
    High Wycombe
    Switching on the engine shouldn't be a problem, although I wouldn't get under the car just in case the vibrations move it (probably over cautios, but that's just me.)
    If you only need to turn the steering, you won't need the power steering with the wheels off the ground.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: Axle Stands...
    Feb 2007
    Nottingham
    Turning the wheels is not a problem but starting the engine can cause vibrations which can move the car off its stands. Ramps would be better if you're doing engine work.
  8. Re: Axle Stands...
    S Wales
    I'll just turn the wheels without starting the car. Cheers boys.
  9. Re: Axle Stands...
    Feb 2007
    Nottingham
    You may need to put the key in and turn it to disengage the steering lock
  10. Re: Axle Stands...
    S Wales
    Yea. Cheers for the help men.
  1. Where to place axle stands?
    By Space Cadet in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-05-2008, 02:07 PM
  2. Axle stands - mk3 Golf
    By tedtheshed in forum Golf MK3 - 1993 - 1999
    Last Post: 05-08-2007, 09:39 PM
  3. Axle Stands - mk3 Golf
    By tedtheshed in forum Chat - Anything with wheels
    Last Post: 05-08-2007, 05:18 PM
  4. How does the Quattro system work?
  5. Using axle stands
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2007, 09:35 PM
