Thread: Passenger Door Handle
  1. Cool Passenger Door Handle
    Apr 2007
    I'm having a problem with the passenger door handle on my '02 Passat Sport.
    When you pull the external handle the door opens about one inch and catches. The second pull opens the door OK. (Just to confuse the issue - it doesn't always happen - about 90%) I'm guessing that there is slack in the cable ?
    If you look at the external handle when it's pulled open, you can see the end of the cable - is ther a way of retensioning the cable from the outside of the car?
    Dublin, Ireland
    My 02 TDI Passat does the same thing - same door too. I recently got it serviced and it seemed ok for about a week after this, although now it's happening again. Less frequently than before (maybe every 1 in 3 times) but always only when the doors are first unlocked.
    I remember reading somewhere that this was an issue with this model? Doesn't stop it being annoying though!
    Oct 2005
    Lutterworth
    Quote Originally Posted by neilc View Post
    Just above the door lock, covered by the door seal, is a torx-T20 setscrew that secures the blanking cover at the rear of the handle.
    Slacken it off, remove the cover, and you can adjust the cable by repositioing the cable end.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    7 Post(s)
    Quote Originally Posted by Lex Luthor View Post
    As Mr Luther has said but in addition...
    The adjustment is via the cable end being a square plastic 'nipple' with serated edges, these edges locate in a corresponding square receptical also with serations. Adjustment is via moving the cable serated 'nipple' out so that it grabs the next set of serations.
    All done once the lock barrel is out.
    Apr 2007
    Thanks Big Col (and you too Lex)
    I'll give it a try on the weekend
  1. Loose Door Handle
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 05:12 PM
  2. Inside door grab handle
    By redadair in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2008, 08:43 PM
  3. golf mk4 door handle
    By valley rower in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2007, 12:40 PM
  4. Drivers exterior door handle problem
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-04-2007, 09:24 AM
  5. Door handle/window switch trim
    By Bod in forum Passat - Archive Topics
    Last Post: 07-11-2006, 10:51 PM
