Thread: Transporter T5 1.9 85PS
  1. Transporter T5 1.9 85PS
    Jun 2009
    Cardiff, South Glam
    Hi, first post for me here! I have a 2005 T5 Transporter SWB with a gear/clutch problem,I'll say what happened and then list the "symptoms". hopefully someone can help.. OK I was pulling away in 1st from a stand still, as I as engaging the clutch something gave way and I was left with engaged gear and a grinding noise with zero power to the wheels. AA /VW and mates have said different things, I initially thought it must be the clutch.
    1) I can engage all gears with no problem if I depress the clutch - no grinding noise
    2) I can engage all gears with no problem without the clutch - grinding noise
    3) After using clutch to engage, on releasing the clutch - the same grinding noise.
    gear change seems fine, various opinions are clutch / driveshaft / differential / final drive gear??? any help would be appreciated. thanks in advance.
  2. Re: Transporter T5 1.9 85PS
    Cornwall
    Drive shaft. It's a two piece one and it strips where the two join. Common fault.
  3. Re: Transporter T5 1.9 85PS
    Jun 2009
    Cardiff, South Glam
    Thanks for that, also ties in with possibility from AA, one extra question then, is a tow advisable or will the turning wheels cause more damage?
  4. Re: Transporter T5 1.9 85PS
    Cornwall
    I wouldn't tow it unless it's only a very short distance. Not because of the shaft, that's condemned anyway. But because of the differential which will be working overtime with only one shaft turning. For the diff it would be like driving ten miles or whatever in a circle with the steering hard on the lock.
  5. Re: Transporter T5 1.9 85PS
    Jun 2009
    Cardiff, South Glam
    thanks for all your advide T5 TDI. appreciate it.
  6. Re: Transporter T5 1.9 85PS
    Aug 2009
    Cardiff Wales
    Hi There T5for bikes. The same thing happened to me a few days back & had to get a flatbed tow lorry via the AA from Reading to my Home In llantrisant. Did you get yours fixed & did you use a VW Garage or a local garage. I would like your advice if poss. i have an 05 130 T28 2.5 model.
    Regards
    Richard
  1. Vw 2005 2.5 Tdi T5 Transporter
    By bigtee in forum The Commercial Range
    Last Post: 10-01-2011, 09:38 PM
  2. Vw 2005 2.5 Tdi T5 Transporter
    Last Post: 25-06-2010, 03:01 PM
  3. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  4. T5 Transporter Using Water
    By david64 in forum The Commercial Range
    Last Post: 27-11-2008, 05:32 PM
  5. Transporter T5 central locking (fitting an alarm)
    By iamrinswind in forum The Commercial Range
    Last Post: 04-05-2008, 06:18 PM
