Thread: locating thermostat
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: locating thermostat
    Sep 2008
    chester
    17 Post(s)
    If the temp is dropping down to 70 quickly and back up it is almost certainly the temp sender,mine did the same,you could watch it drop in a matter of seconds,I changed the stat also but no joy!I would change the sender £30 for the part,it will have a dramatic effect on your mpg!,also there were no fault codes stored
  2. Re: locating thermostat
    Bear i mind that the sensor has two seperate elements. One drive the gauge and the other the ECU. MPG is not effected by the gauge element and I doubt both have failed at the same time. If the car is noticeably slow to warm up and heat the car then it applies the stat is at fualt. However you do mention that in traffic if drops to 70-75 and I would expect it to rise and then drop when you are moving agian and more airflow. If you park the car for say 15 minutes and then restart does the car indicate 88/90 ish as this would implyt the sensor is OK although worth checking the connecter for corrosion. Regards Peter
  3. Re: locating thermostat
    May 2009
    worthing
    got the thermostat and 'O' ring yesterday, will fit soon and keep you updated. Regards, Dan
  4. Re: locating thermostat
    May 2009
    worthing
    Changed thermostat last night, took the car for a drive around town, engine heated up after 10 min with temperature dead on 90. Drove to work this morning - motorway, temp dead on 90 and oil 100 . It looks like it was a faulty thermostat even though the old one wasn't stuck open when I took it out. Many thanks, Dan
  1. cracked thermostat housing!
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 15-05-2008, 06:34 PM
  2. 80 TDI thermostat change
    By Grey Import in forum 80 - 90
    Last Post: 21-02-2008, 12:41 AM
  3. Locating Thermostat on AGG 2.0l 8v
    By P745FPM in forum Golf MK3 - 1993 - 1999
    Last Post: 13-02-2008, 12:33 AM
  4. Golf Mk IV Engine temperature dropped
    By mangoman in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 11:11 AM
  5. Price of thermostat (2.0 petrol)
    By edihans in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-11-2007, 03:29 PM
