Thread: strange one (electric mirror problem!!)
  1. strange one (electric mirror problem!!)
    Right guys, I often adjust the drivers mirror downwards to assist while parking, (still zero marks on my precious monza's!!)
    However while adjusting it today i noticed something strange; both mirrors were moving !!!
    On closer investigation i found;
    - Switch rotated to 'R' position; Both mirrors move up and down; Mirrors move opposites when moving left and right
    - Switch rotated to 'L' position; Only Left mirror moves as it should..
    Any suggestions ?? Anyone seen or heard of this before ??
    Think i could be the switch unit that has malfunctioned, or a problem with VAGCOM coding..
    XXXX - Not longer a problem, just found out its supposed to do this !! XXXX
    Thanks in advance, Z
    Last edited by zub-gti; 16-06-2009 at 07:34 PM. Reason: Found solution ! - Its supposed to do that !!
  2. Re: strange one (electric mirror problem!!)
    That is the way they function
  3. Re: strange one (electric mirror problem!!)
    Coventry
    its explained in the hand book and it even suggests you position one side before the other.
  4. Re: strange one (electric mirror problem!!)
    May 2009
    Australia
    Not certain about it but I have an idea there's a setting in the MFD under (convenience) which allows the option for either individual mirror adjustment or both at once. As suggested check up on it in the manual.
    RUSS
    2008 VW GOLF GT TDI, 6 speed manual, Sunroof, RNS 510. Chipped UK ST3
  1. Advice on Golf electric problems
    By spainy in forum Golf MK3 - 1993 - 1999
    Last Post: 02-05-2008, 09:28 AM
  2. Strange Occurance With My Electric Windows
    By pedropete27 in forum Bora - 1998 - 2005
    Last Post: 04-03-2008, 12:05 PM
  3. strange electric window fault!
    By JezT in forum Golf MK3 - 1993 - 1999
    Last Post: 11-02-2008, 01:20 PM
  4. electric windows fail
    By happysnappy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2007, 12:26 AM
  5. Replies: 0
    Last Post: 24-10-2007, 07:38 PM
