Thread: TDi electrical problems
  1. TDi electrical problems
    Nov 2008
    Afternoon Guys,
    Problem with my 97 Tdi sport. I went to start it this morning and engine started fine however indicators, wipers and air con motor failed to work. Air con controls system flashed for 30s but then was ok, Radio was ok.
    Guessing it maybe a flat/flattening battery as car hasnt moved much in recent weeks - short runs of 1-2mile at a time.
    Any thoughts on what the source problem is? or how best to rectify the problem? (obviously if flat battery charge it)
    Craig
  2. Re: TDi electrical problems
    Jan 2009
    towcester northants
    try a x relief relay
  3. Re: TDi electrical problems
    Dec 2006
    I had this exact problem last week on my 97 tdi sport, it was the ignition. When you start the car you may find the ignition is still turned too far around, try moving it back, as if you were going to turn it off but not quite. I've been told that a squirt of wd40 in the ignition barrel may free it up a bit, I will try it on mine
  4. Re: TDi electrical problems
    Nov 2008
    Quote Originally Posted by towcestervag View Post
    Cheers mate,
    Not total sure what you mean - my mechanic skill are a bit basic.
    Ta
    Craig
  5. Re: TDi electrical problems
    Nov 2008
    Quote Originally Posted by TDi_B5 View Post
    Cheers will give it a go in the morning
  1. Car not starting and other electrical problems!
    By u03am5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-04-2009, 04:39 PM
  2. Golf MK5 Electrical Problems
    By mth700 in forum VCDS - General Questions
    Last Post: 20-05-2008, 09:38 PM
  3. golf mk4 gt tdi 115 any problems?
    By burne in forum Golf MK4 - 1999 - 2004
    Last Post: 01-05-2008, 04:40 AM
  4. 50mpg-plus Audi Diesel Sports Car Cleans Up In Geneva
    Last Post: 27-02-2008, 10:24 PM
  5. ELECTRICAL PROBLEMS 1998 VW GOLF 1.9 TDi
    By Tim Watkinson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-12-2006, 02:57 PM
