Thread: Which oil 2 use
Results 1 to 10 of 10
Hybrid View
  1. Which oil 2 use
    Feb 2009
    Hi just a quickie my car is not due for a service till next year, but being a diesel it has been suggested to me that it would be a good idea to change the oil this year.
    It was vw serviced in october i will be towing in a few weeks so i thought i would give it an oil change.
    heres the question can anybody suggest which oil to use iam led to believe the vw oil is dear and its long -life (dunno if this makes a difference) is there an equally as good oil (possibly cheaper - e.g. mobil , castrol, amsoil)
    that will do till vw service it again next year.
    my car is 2006 Passat 2.0TDi sport.
  2. Re: Which oil 2 use
    Sep 2007
    South Manchester
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  3. Re: Which oil 2 use
    Rutland
    If the car is on the variable (long life) service regime and you wish to keep it that way then you must use an oil meeting the VW 507.00 spec. If you don't the car will default to the time and distance regime and won't allow reverson to variable. You can get away with a small amount of non VW 507.00 top-up but not a complete change.
    There are cheaper alternatives to VW's own brand 507.00. I use Comma and I believe ********* have their own now. It does not matter whose name is on the tin just that it says on the tin it meets VW 507.00.
    Personally I would not bother with the change. If towing accelerates the oil degradation then the variable system will call for the service to be brought forward if necessary. That's what its designed to do.
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  4. Re: Which oil 2 use
    Jun 2008
    Interim change is a good idea in my opinion.
    I got a deal on halfords 507 spec oil when i did mine and got filter from dealer.
  5. Re: Which oil 2 use
    Sep 2007
    South Manchester
    The dealers all seem to use the 507.00 irrespective of service schedules, I know 505.01 is ok for 10K PD non-DPF 140's. I used to use the millers in my 115 alhambra but carry a 1 litre bottle of the millers for top-ups.
  6. Re: Which oil 2 use
    Feb 2009
    Thanks for the replies, i had read somewhere that diesels are better if they have the oil changed regular i.e yearly.
    I hadn't really thought about the variable service bit i had just thought every 20k thats it a new service is needed.
    Just dawned on me i have a vw topup pouch in the boot - inside it is a Castrol SLF longlife II 1 litre topup so i presume thats what vw have put init.
  7. Re: Which oil 2 use
    Feb 2009
    hi gamichea looks like you were right about the variable service (thanks M8) i just found this on the tinternet.
    LongLife Servicing and Castrol SLX LongLife II
    How advanced engineering and oil has changed the way your Volkswagen is serviced.
    LongLife Service Regimes
    The LongLife Service Regime is so called because there are no set service intervals and, depending on
    how you drive your vehicle and the conditions of use, a service will be required anywhere between 9,000
    miles or 12 months (whichever occurs first), up to a maximum of 30,000* miles or 24 months (whichever
    occurs first)
    This LongLife regime has been made possible due to the development of new Volkswagen engines with
    the latest technically advanced longlife oil. These engines use built-in sensors that continually monitor the
    oil quality, making it possible to enjoy reliable and confident motoring for up to a maximum of 30,000*
    miles or 24 months (whichever occurs first)
    * The maximum of 30000 miles is for the 3 and 4 cylinder TDI diesel engine. All other diesel and petrol
    engines have a lower maximum mileage. Please consult your Volkswagen Retailer or repairer for full
    information.
    It’s your choice.
    All new Volkswagen cars (except the Lupo) are now manufactured with the LongLife service regime
    activated and the engine filled with longlife oil. However, your car is also capable of being serviced at a
    more traditional time of 12 months or 10000 miles (which ever occurs first). This regime is known as
    Time/Distance or Fixed for the Lupo.
    Your Retailer will explain both systems and can reset your car to the Time/Distance regime at the Pre
    Delivery Inspection.
    Whichever regime you choose, the vehicle dashboard service indicator will remind you when the service
    is due. With the Time/Distance regime this will be around 10000 mile or 12 months (which ever occurs
    first). With the LongLife service regime it could be anywhere between 9,000 miles or 12 months up to a
    maximum of 30,000* miles or 24 months, depending on the engine.
    What LongLife Servicing can mean to you.
    • Fewer visits to your Retailer or repairers workshop.
    • Lower lifetime service costs.
    • Less oil to dispose of, which is kinder to the environment.
    • Fuel saving.
    Your Retailer has a computer calculation that can illustrate the likely savings you will make on both the
    maintenance of your vehicle and the fuel bill using the LongLife and Time/Distance regimes.
    Castrol SLX LongLife II Engine Oil.
    Castrol SLX LongLife II is a fully synthetic engine oil formulated to satisfy the requirements of the
    Volkswagen LongLife service regime.
    Not only is Castrol SLX LongLife II capable of meeting the demands of longer service intervals for
    both petrol and diesel engines, it is also one of the few oils that is approved to the Volkswagen
    Group standard for the latest generation of the ‘Pump Duse’ or PD direct injection diesel engines.
  8. Re: Which oil 2 use
    Feb 2009
    here the address for the full thing if anybody wants to read it.
    http://pics.tdiclub.com/data/3005/30..._servicing.pdf
  1. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  2. Answers From The Oil Expert Part 2
    Last Post: 22-10-2007, 08:30 AM
  3. Answers From The Oil Expert
    Last Post: 22-10-2007, 08:28 AM
  4. Answers From The Oil Expert
    Last Post: 05-10-2007, 03:25 PM
